Which engine is a "G" code in 1989?
Old Dec 9, 2011 | 08:34 PM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by EPNCSU2006
ZF lists 5.24 for wide-ratio reverse in their documentation.
If the tooth counts are correct, the math works out to 5.238.
http://www.zf.com/na/content/media/u...arRatio_60.pdf
LOL :)
Doggonit, now I wonder where I got my number from. :)
Alvin in AZ
Old Dec 9, 2011 | 09:26 PM
bruno2's Avatar
bruno2
Originally Posted by andym
I coulda told you that.
They are very hard to find, but a few 1988 F-150's and possibly Broncos were made with the 351w/ZF-5 combination.
I thought I just read somewhere that there were a few special order Broncos with the zf5 set up special ordered from the factory.
Old Dec 9, 2011 | 10:42 PM
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by Alvin in AZ
I've seen that mistake repeated lots of places so wanted to get it
right here is all. The reverse gear ratio is the same as first = 5.72.
Dont know what yours has in it, but mine has a 5:24 reverse
Old Dec 10, 2011 | 04:26 AM
Iversen-fords's Avatar
Iversen-fords
I'm a little late here but, wasn't the W code in the later models just a HD 5 speed. I only thought ford had 2 manual trannys to offer but the owners manual made it sound like there was 3.
Old Dec 10, 2011 | 08:47 AM
lvin4jc's Avatar
lvin4jc
I saw that listed somewhere as well but with no other info about it, manufacturer, specs etc.
Old Dec 10, 2011 | 09:01 AM
Diesel_Brad
Ford did offer (8) 5 speed OD trans. 16 if count 2wd and 4wd
1. the mazda POS only behind 300 and 302
2. ZF5 S42 small block
3 ZF5 S42 big block
5 ZF5 S42 diesel
6 ZF5 S47 small Block
7 ZF5 S47 Big block
8 ZF5 S47 diesel
Oz Econoline
Sep 7, 2014 01:53 AM
mrblonde108
Large Truck
Feb 6, 2011 02:11 PM
pjlandry
Dec 17, 2006 11:36 PM
PAUL_2
Jun 8, 2000 07:42 AM
