Sponsored by: Auxito
heat issues
Old Dec 5, 2011 | 12:28 AM
screamin gt's Avatar
screamin gt
heat issues
everything works, all vents and controls work but only blow cold air. truck gets up to normal temp no problem. had the issue last year and fixed by changing the control unit. Its been fine since up until the other day. The control **** for "hot/cold" seems like it spins very easy, like theres no resistance when you turn it. I think it was that way last time I changed it to but I dont remember.
I tried searching but couldnt find anything similar.
does this sound right?
Old Dec 5, 2011 | 05:54 AM
Dave G.'s Avatar
Dave G.
Check the plastic **** for a crack around the control shaft opening. If there is one, it'll get spread even larger when the **** is pushed back on, and may not turn the shaft.
Dave
Old Dec 5, 2011 | 09:21 PM
steve(ill)'s Avatar
steve(ill)
all the vents and air flow are controlled by vacuum cylinders. The "heat" is controlled by the **** that sends a variable electrical signal to a motor that moves the mixing door in the duct to mix hot and cold air. You can have a bad electrical controller, bad motor, bad gearbox on the motor, or bad duct door .
Old Dec 15, 2011 | 08:12 PM
screamin gt
I replaced the heater/a.c. control unit and nothing has changed. I ran to full temp and thermostat opens, water pump works, no leaks.
does this all mean its a bad duct door? from any posts I read that seems like its a pita to fix. how much would I expect to pay to have it done? I really don't have the time to get into it right now myself.
Old Dec 27, 2011 | 01:08 AM
screamin gt
ttt anyone
Old Dec 27, 2011 | 08:13 AM
Baer's Avatar
Baer
I ordered the kit from heatertreater.net. Took me about 2 hours. Got heat now.
Old Feb 16, 2012 | 09:12 PM
screamin gt
bad duct door... quoted $700+ to fix. I know I could do it myself but I don't have the time so my loss is their gain on this one.
Old Feb 16, 2012 | 10:03 PM
galaxie641's Avatar
galaxie641
I assume they have to remove the dash for that price, if so I'd have the heater core done at the same time.
Old Feb 16, 2012 | 10:04 PM
screamin gt
wow, wish I saw that heatertreater.net post last week. I'm gonna print that out and bring it to the shop and hope the guy didnt start on it yet cuz he will surely go for it with this...
Old Feb 16, 2012 | 10:05 PM
screamin gt
I'm gonna hope for a year or two more out of this rotting truck, and then maybe get a brandy new truck. I heard some of the new models come with an automatic divorce. j/k lol
longt
Mar 31, 2017 04:27 PM
ligito
Jul 28, 2015 08:03 AM
ford351c
Jul 5, 2006 12:58 PM
joe35098
Jan 17, 2006 08:09 PM
badge250
Aug 19, 2004 01:45 PM
