heating
Old Aug 18, 2004 | 05:15 PM
badge250's Avatar
badge250
heating
I have a 99 f250 sd 7.3 my heat system sometimes work normal but sometimes it blows cold air. I can have the heat on, and it works fine. turn it off and then turn it back on again and it only blows cold air. the temp of the motor never changes. I have looked behind the glove box and all looks normal. sometimes the heat will never come on and only blows cold air. any info would be helpfull
thanks
Old Aug 18, 2004 | 06:13 PM
HomerWinzlow's Avatar
HomerWinzlow
With the age of your truck the blend door controller may be fritzing out. Its not very expensive if thats what it is and can be replaced relatively easy on the super duty.
It could be as simple as a cracked control ****.
Old Aug 19, 2004 | 01:45 PM
badge250's Avatar
badge250
HomerWinzlow
is there a way to check out the blend door? It looks like it operate nml, when you go to off postion it goes full closed and when you go through each postion on the control **** it moves. What lets the heat come through is it the blend door?
BDSSUperDuty37
6.4L Power Stroke Diesel
Mar 16, 2015 09:50 AM
TG-Digz
Dec 15, 2013 08:10 AM
Big Norm
1997 - 2003 F150
Sep 16, 2013 09:53 PM
kevbits
Oct 4, 2009 12:19 PM
nbondy2
Jan 25, 2008 09:44 PM
