trying to find ecm 89 e250 help!
Old Dec 4, 2011 | 05:21 PM
justforkicks's Avatar
justforkicks
My buddy has a donor ECM for my 87 f150 and we were going to test it in my truck. it's a 300 i6 c6 combo. we checked kick panels and under the hood and what not. where is the ECM?
Old Dec 4, 2011 | 07:07 PM
kb1jid's Avatar
kb1jid
If its in a 89 E250 its under the heater box
Old Dec 4, 2011 | 08:21 PM
justforkicks
is it bolted down to the floor? pull up the carpeting?
Old Dec 4, 2011 | 09:01 PM
kb1jid's Avatar
kb1jid
No its up under the heater box inside the van. there is a cover about 6" by 8" that you remove then the ecm is there then under the hood under the heater you need a 10mm socket to loosen the bolt that holds the wire con to the ecm then you can remove it from inside the van
Old Dec 4, 2011 | 09:06 PM
justforkicks
alright. yeah me and my friend were searching and searching at the typical places ford pickups usually had them and found nada. thanks!
Super Econoline
Mar 6, 2013 02:51 AM
racinrob
Nov 17, 2008 06:15 AM
omni
Oct 15, 2004 11:12 PM
Oregon Rob
Feb 23, 2004 02:48 PM
rickthefix
Dec 2, 2003 11:43 AM
