Door switch failure ????
Old Dec 3, 2011 | 10:28 PM
dvldog458's Avatar
dvldog458
Question Door switch failure ????
I'm having trouble with my door switch. It's an intermittent problem. Sometimes I'll open the door and the interior light wont come on, but when I put the key in the ignition and turn it, they come on.
Has anyone experienced this?
Old Dec 4, 2011 | 10:17 AM
saz2686's Avatar
saz2686
I would try spraying all the door switches with oil/lubricant. When I got my truck it had the common door ajar light driving me crazy. The first round of spraying did not fix it. The next day I sprayed again and did some aggressive closing/opening and to my disbelief it worked. Gotta be worth a try if you haven't already! I sprayed inside the hole where the little black bar goes in the door. Sorry for the lousy description.
Old Dec 4, 2011 | 04:53 PM
dvldog458's Avatar
dvldog458
Thx! That makes sense.
This morning I went out to my truck and unlocked the truck via key fob and opened the driver's door......No light!
Then I left the driver's door open and opened the driver's rear door...No light!
I was pissed...i then left both doors open and slammed the driver's door closed and the interior light came on.
I'm gonna hose the **** out of those locks with WD-40.
I'll keep u posted
Old Dec 4, 2011 | 08:08 PM
saz2686's Avatar
saz2686
I'll keep u posted
Haha that's the spirit! Give 'em the oil hose. Driver's door is said to normally be the culprit. Most used, logical I guess.
Old Dec 4, 2011 | 09:30 PM
dvldog458's Avatar
dvldog458
Yeah, The big test will be tomorrow morning at 0500 when I go to start her up for work.
Old Dec 4, 2011 | 09:51 PM
dvldog458's Avatar
dvldog458
Does anyone know what exactly what we are lubricating with the WD-40? Is it mechanical or electrical contacts....just curious.
Old Dec 4, 2011 | 10:12 PM
archtaan's Avatar
archtaan
Its the mechanical switch that gets depressed by the latch. It sends an electrical signal to the GEM or CPU whichever so it knows the door is open. The WD-40 cleans up the grime that gets in there and makes the switch get sticky.
Old Dec 4, 2011 | 11:25 PM
robert_l_ross's Avatar
robert_l_ross
What he said...spray the hell out of all of what you can see if the latch, may need to open and close the door a few times and spray again...it will work its way back into the contacts inside the latch.
Old Dec 5, 2011 | 05:34 PM
dvldog458's Avatar
dvldog458
Knock on wood Boys!
It worked!
Thanks for all the help....
lhud
13
Mar 23, 2022 02:17 AM
ReAX
Nov 24, 2006 11:09 PM
mach2race
Jun 8, 2006 08:33 PM
bigexpo
Jun 23, 2005 10:15 AM
rrs
Feb 4, 2004 12:32 PM
