No Power SES light on running out of things to check
I have a 99 f350 with a 7.3 I have been checking everything that I can read on here to check.
Problem passengers side injectors are not firing
I have ohm the just about everything that people on here have posted to check the only bad reading I get is one of the injector solenoids reads 4.0 ohms but I swapped solenoids and it stays with the same injector, took gasket out and ohm all connections which seemed to be ok
Question Can the injector itself give a bad ohm reading otherwise what else can I check
my e99 did the same thing started off just now and then and then it just went. ohm'd everything, all good, while i was in it done the .50 mod replaced idm and was all good. for the sake of i would look at the harness all the way to the idm just make sure you don't have a place rubbed in it if i remember corectly mine had started rubbing at the driver valve cover caught it before it was a problem
