6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Dpf delete ?
Old Dec 9, 2011 | 02:56 PM
smotrs's Avatar
smotrs
I wouldn't bet on it.
Old Dec 9, 2011 | 03:41 PM
StanleyZ's Avatar
StanleyZ
Originally Posted by gambling209
it doesn't really matter. if you take your truck in and they pull up how may times it went into regen. they will know what you have been doing.
Yeah, haden't thought of that. But it sounds right to me.
Old Dec 9, 2011 | 03:54 PM
aquaman's Avatar
aquaman
Here's my $0.025. If I was the PCM firmware engineer, I'd have log registers that record the hour meter or odometer reading of the last PCM update(s), the last regen(s), the last reset reason(s) of the PCM, TCM, etc, and peak values of all sorts of parameters--they won't take up much space. To prevent tuners from messing with it, I can simply encrypt those log registers and/or scatter them around throughout flash. Nonvolatile flash memory is cheap these days, so this is easy to do.
It seems Ford can see when the last few regens occurred and how long they were based on some comments by someone who took their truck in to diagnose some regen issues.
If the last PCM update is logged based on hour or odometer, it'll be a dead giveaway too. They'd simply match it with when they think Ford did the last update. To make life easier, they could also record the CRC's of the last calibration(s). IF they don't match what Ford published, then....
The reality of it is, if a numb-numb like me can think like this, I'm sure the Ford engineers did so and figured us out a long time ago
Old Dec 9, 2011 | 03:55 PM
sdetweil's Avatar
sdetweil
Originally Posted by 08f3506.4lsgs
Cool thanks I'll have to check it out. Is it true that spartan is the only company out that is not detectable by ford?
Shaun
you don't have 25 posts yet (FTE requirement), so I can't email u directly.
I have a spartan I no longer want.
my email is my userid at gmail.
Sam
Old Dec 9, 2011 | 05:20 PM
StanleyZ's Avatar
StanleyZ
Don't forget now, these computers were programmed in what, 2006? I'm told 5 years is a lifetime in computer programming. Not doubting what you say, just reminding you.
bholicz
Feb 3, 2013 06:46 PM
cmalley12
Apr 24, 2012 04:21 PM
Fort Mac Ford
Apr 25, 2011 08:42 PM
slash36g
Computer Chips & Tuners
Dec 21, 2008 08:48 AM
