Offroad & 4x4
Shocking
Old Dec 2, 2011 | 12:05 PM
fatdan460's Avatar
fatdan460
Originally Posted by alpha/omega
^^^Biggest pile of overpriced sheeot Ive seen this week.
just thinking the same thing. even if he only needs them for the front that 80+ bones to rig up cheap shocks. eff that noise.
Old Dec 2, 2011 | 02:37 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
Yeah for that price I'd be halfway to a set of new shocks that fit!!
Old Dec 2, 2011 | 04:58 PM
77mud's Avatar
77mud
at that price id be all the way to a set of shocks that fit.... eff the expensive ****... run the cheap ones from advanced
Old Dec 3, 2011 | 04:20 PM
SwOkcOffRoader
I was looking at the $17 ones at Oriellys. I was actually about to get them, then I came across these in a storage container at work. The price tag on the oilpan was $50, so I think I did ok price wise. They aren't the best or worst shocks, but they will be better than nothing. I cut some 3/8" steel tabs to weld up some mounts. I was going to make my own adapters like pictured, then it hit me, to just weld the tabs on the shock mount bracket and save a step. I also have tabs made for the upper mount, gonna make it just a bit taller than the ones pictured.
Old Dec 14, 2011 | 10:33 PM
mbxmitch's Avatar
mbxmitch
Sorry i posted wrong place im on a phone
Old Dec 18, 2011 | 01:31 AM
SwOkcOffRoader
So I've been doing a little booty fab work at the shop. I'm not done grinding on these before paint, but I think they will do the trick for my bottom front mounts. I cut them out of scrap 3/16" plate with a plasma cutter, then grinded them smooth, and had a welder at my shop burn em together since my welding skillz are minimal. They still need more grinding inside so the big bolt will sit flush and have enough clearance off the shock.
The sockets are exactly the right length.
I think this should be stout enough...
I still need to finish grinding so it has more clearance...
I gotta get the truck to my shop to get the uppers started. But at least I got something going.
Old Dec 18, 2011 | 10:32 AM
73 ford guy's Avatar
73 ford guy
Looks good. Holes could of been maybe just a C hair higher for better clearance but looks like it will work. A guy could make these out of pieces of square tube as well with the top cut out to eliminate the welding. Are you going to weld the bolt head tops? I would.
Old Dec 18, 2011 | 11:17 AM
SwOkcOffRoader
Yeah I searched our metal yard, but couldn't find any tubing the right size. That was my original plan. So I just fiddled with some flat plate. Yes I'm welding the bolt head after I grind the inside welds. Right now the hex head hits the weld beads so it won't sit down flat. I estimate it should have just shy of a 1/4" of clearance. It's hard to see that in the pics. Best part about these is the price, free!!!
Old Dec 18, 2011 | 11:19 AM
SwOkcOffRoader
I thought about buying a 20' stick of the right size tubing, and some hardware. Them sell em for $39.99 a set. I'm also trying to think up other simple fab stuff to make in my off time at work to maybe help buy parts!!
Old Dec 18, 2011 | 11:52 AM
73 ford guy
Don't think these would be too much in demand. It's a fix for an old style that's almost all but gone. No one uses pin style anymore really I don't think. The other option would of been to put tabs on bottom.
Old Jan 6, 2012 | 08:07 PM
SwOkcOffRoader
Went by pull a part today. Found these upper shock towers on an 89 F250 4x4 for $11.87. Not only do they have the mount holes I need, but they are taller than my current ones, so these longer shocks will fit better. One step closer!!!
WNDOPDLR
Jul 9, 2018 09:43 AM
Chris3
Apr 14, 2018 06:17 AM
400inatruck
May 24, 2012 10:31 PM
71hightoy
Offroad & 4x4
Nov 19, 2009 11:09 AM
chrisford410
Apr 6, 2009 11:55 AM
