Offroad & 4x4
Shocking
Old Nov 30, 2011 | 08:51 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
Shocking
so i scored a set of fairly used skyjacker hydro 7000 shocks w/steering damper and a chrome oil pan to fit on the ol' 351m....i got all of it for $50 from my boss....
my problem is that the mounts are different...the lower rears will work fine, i will have to fab a mount for the upper rears...
the fronts are a different story, the stock mounts are the type the shock goes thru holes on both ends...the shocks are the type with round ends and round bushings as you can see...i have a couple different ideas to fab up mounts that will just bolt into the factory mounts...but im looking for some feedback on any ideas to convert the mounts...cause im probably overthinking as usual....
the steering damper has the same issue as the front shocks, both ends are different...so if anyone out here has this style of shock mounts, please share your pics...thanks!!!
Old Nov 30, 2011 | 10:01 PM
fatdan460's Avatar
fatdan460
i'd probably just go with something like this. simple and worst come to worst you can torch and bend or miter cut tube and weld it if you can't get access to a bender.
the other more hillbilly idea i have floating around is use a angled small piece of box tube and drill it and just use spacers to hold the bushing tight if you get what i mean, kinda butch though....
Old Dec 1, 2011 | 03:30 AM
tjc transport's Avatar
tjc transport
i ain't rite
and if you are going to use that oil pan, grind all the chrome off the gasket surface before you use it, or you will never be able to seal it.
Old Dec 1, 2011 | 04:28 AM
77mud's Avatar
77mud
Shocks??????????????????? WHO THE BLLLLLEEEEEEEPPPPPPPPPPPPP USES SHOCKS??????????
:womenpart:
lol jk
maybe...
Old Dec 1, 2011 | 05:50 AM
hav24wheel's Avatar
hav24wheel
F250 shock mount
Thoes bushings apear to be missing a metal sleave...
Old Dec 1, 2011 | 06:44 AM
SwOkcOffRoader
Yeah I think all the sleeves are MIA. They are probably in the misc bolt bin at work. If not they are pretty easy to make from materials at ace hardware. Does it matter if the shock boots or up or down?? Of is it just which ever way I think looks better??
Old Dec 1, 2011 | 08:05 AM
alpha/omega's Avatar
alpha/omega
You can use 99-04 SD shock mounts.
Old Dec 1, 2011 | 11:01 AM
mark a.'s Avatar
mark a.
I use that kind of shock but I paired them up, they sucked just single.
Old Dec 1, 2011 | 06:22 PM
73 ford guy's Avatar
73 ford guy
Do this.. Cut the top and weld on tabs
Old Dec 1, 2011 | 07:02 PM
SwOkcOffRoader
That's one heck of an idea, so friggin simple!! I knew I was over thinking it!!! What did you do on the bottom??
Old Dec 1, 2011 | 09:58 PM
73 ford guy
I actually went with a pin adapter for bottom. A 3/4" threaded rod to bolt to mount with a U shape saddle with holes welded to top. Its made by some company but I cantt remeber. Its bling yellow zinc though. lol
I would make some tabs now that I have welders and proper tools I was just lazy..works fine though
Old Dec 1, 2011 | 10:00 PM
73 ford guy
here ya go
TOTAL CHAOS 30012 Universal Pin to Eyelet Shock Conversion Adapter
Old Dec 2, 2011 | 06:33 AM
alpha/omega
^^^Biggest pile of overpriced sheeot Ive seen this week.
Old Dec 2, 2011 | 07:04 AM
SwOkcOffRoader
That's even better than what I was thinking, once again, "overthinking" kills me. I for sure won't spend money on it, I can build em for free. Thanks for the pics, it's exactly what I needed!!! Now to just git er done!!!
Old Dec 2, 2011 | 08:47 AM
73 ford guy
Yup. X2.
