Has it been done?
Old Nov 29, 2011 | 01:54 PM
TexasDiesel97's Avatar
TexasDiesel97
Has it been done?
Hi guys popin in from the OBS Powerstroke side. I've got an 86 F-250 6.9L SC LWB 4sp 4x4, and i'm looking to swap in a ZF 5 spd cause of the O.D.. My question is what do i need to do the swap? I know i need a 4x4 ZF trans and matching flywheel, but what else? Any and all help and info is greatly appreciated, thankyou.
Old Nov 29, 2011 | 02:02 PM
starmilt's Avatar
starmilt
It has been done a lot, on this very page there is a couple ongoing threads for it.
You will have to decide what type of flywheel you want to use, and I think you will need the crossmember from the donor too.
Old Nov 29, 2011 | 03:41 PM
1994F2507.3L's Avatar
1994F2507.3L
like star said there's 2 flywheel options. single mass and dual mass. the dual mass is the stock clutch system. but more expensive than single mass. if you convert to single mass. id use the south bend setup. seems pretty solid.
South Bend Clutch Catalog - Ford Clutch Kits
Old Nov 29, 2011 | 03:46 PM
joe f350's Avatar
joe f350
u will allso need the front and rear drive shafts
Old Dec 2, 2011 | 01:26 PM
TexasDiesel97
So all i need is a trans, transfer case, flywheel, crossmemeber, and drive shafts? Hmm, parts list is shorter than i anticipated.
Old Dec 2, 2011 | 04:44 PM
farmert's Avatar
farmert
The transfer case from the 4sd will bolt to the ZF. When I put the ZF in my 85, all I used was the ZF and the crossmember. I used the 208 case that was behind the 4sd. The ZF and the T19 with the transfer case adapter were close enough to the same lenght that the driveshafts worked. I did however use a SMF conversion for a 7.3 IDI because I couldn't find the right clutch and pressure plate for the 6.9 that would fit the input shaft of the ZF.
Old Dec 2, 2011 | 10:35 PM
Sycostang67's Avatar
Sycostang67
I believe you will also need the removable floor section that is above the transmission. The ZF plate is taller to clear the transmission.
Old Dec 3, 2011 | 11:04 AM
farmert's Avatar
farmert
Good point Syco, I forgot about that.
Troyus
Feb 15, 2016 06:54 PM
Country_boy_2007
36
Mar 2, 2015 10:36 PM
goodtyms1432
13
Jun 16, 2010 09:33 AM
mooney456
Jul 3, 2005 04:35 PM
Sam Wactor
Dec 9, 2002 09:10 PM
