Guys, I am trying to sort out the steering on this 77 F100. 2WD, PS, 300 CID motor. Yes, I have searched the forums and the web.
I don't think there is a lot of play in the system. If I put the front end on jacks, I can't wiggle the tires. With a pry bar, I can't get the idler arm ball joints to move in any obvious way. I have a new used flex coupler. On a flat road, it does not have an obvious pull, but over about 1/10 mile it will work to the right shoulder.
If I move the steering wheel, the tires move. The problem I have appears not to be "play", but just too much sensitivity. When driving at about 35 MPH, you can put a fingertip on the wheel and easily move it an inch and the truck will change lanes. That's not too much of an exaggeration.
What do I do to tighten this up without throwing parts at it? I'm about ready to disconnect the PS pump until I get it fixed.
sounds somewhat normal. mine is real sensative. i know that red head steering gears
has a way to slow it down some as far as response. but other than that i dont know
what else to do.
i am by no mean an expert, but thru all my reading, i vaguley remember someone posting something about having power steering box wrongly rebuilt, (gear ratio of some sort ) on the inside is wrong.
where you would normally require 1/2 turn of the steering wheel, now you can do it with 1/8 of a turn.
I could not find the thread, i have been reading, tons of post before i start swapping.
An adjustable power steering valve is available in the aftermarket to reduce the line pressure and its twitchiness. It's a Heidts' piece but I recall others. For example, go to yogisinc.com and search for PN PS-101.
Otherwise, has the rig had an alignment recently? Could be caster issue. Or, an undersized PS pulley? Hmmmm....
My truck was twitchy and it ended up having too much toe in. Adjusted it myself to 1/8" and its good. Truck has been well over 100 too It still has quick steering but im used to it.
I have an 77 F-250 with very loose steering. I can hold the steering wheel still and the truck will wander on the road then vise versa, I can move the steering wheel 5-6" in either direction and the wheel won't move. I've check the other steering parts which are in fair condition. My repair manual mentioned an adjusment of the steering gear to increase or decrease the sensitivity of the steering. I made the adjustment and it tightened the play but my gears are worn as the wheels still wander but after the adjustment there is no longer the 5-6" play in the steering wheel. I have ordered an reman steering gear. I would suggest adjusting the steering gear prior to any purchases. Just my two cents.
I believe that would have to do with toe for the sensitive steering.....
I will check the toe. Working on it today. Will also install the Heidts valve to reduce hydraulic pressure to the steering box. I'll report back when I get done.
Check for play in the whole system leaving it on the ground. One person to move the steering and one to look. Anything thats wrong will show up a lot easier with load on it.
