oil cooler change help
Old Nov 28, 2011 | 07:05 PM
draboo's Avatar
draboo
I am gonna do a coolant flush when I get back home. Today the temps were running around 10 deg apart. I only hit 190 once for around a minute, but the oil was at 199. If these temps do not come down after a thorough cooling system cleaning, I'm thinking seriously about changing the cooler.
Are there instructions anywhere on how to change only the oil cooler? Are there other components that should be changed along with it? I have no freakin' idea how to do it. I believe I m capable of doing it..just don't have any idea on what needs to come off, or in what order it needs to be done.
It being a 2003, it has the round EGR cooler, so I m thinking I'm good there. Presently, the truck starts great, no white smoke in the morning and runs strong. I m thinking the only other real mod I would like to do for reliability would be either the "BB" or the "blue spring" for fuel pressure.
Any links for changing out an oil cooler would be greatly appreciated. I sure don't want to start something I cannot finish, especially when this is our lone (4 wheeled) vehicle.
Thanks,eh?
Brad
Old Nov 28, 2011 | 07:12 PM
BLADE35's Avatar
BLADE35
10 degrees aint to bad does it get further apart than that
Old Nov 29, 2011 | 06:50 AM
draboo's Avatar
draboo
I saw it at 15 deg apart for a brief period. It's been hard to get the water to 190 with the cold weather.
We will see what happens after the cleaning of the cooling system.
Old Nov 29, 2011 | 07:17 AM
bismic's Avatar
bismic
Thanks,eh?
Brad
PM me your email address and I can send you a fair bit of stuff on the oil cooler changeout.
Old Nov 29, 2011 | 08:55 AM
sammy77's Avatar
sammy77
I would do just that. No need to replace coolers yet if you're just seeing 15 degree spread for brief moments. Especially when towing.
Old Nov 29, 2011 | 07:05 PM
draboo's Avatar
draboo
It finally got warm enough today for the wct to hit 190 for a half hour or so. WOT got up to 202 for a few miles, then dipped back to 199. This is cruising at 70 mph without towing.
bismic: my email is draboo@gmail.com
Old Nov 29, 2011 | 07:10 PM
BLADE35's Avatar
BLADE35
it shouldnt matter the time of year that thermistate should hold the temp at 190* or higher if not it maybe stuck open alittle
If it doesnt you may want to get a new one in it anyless than 190* and your fuel milage may suffer
Old Nov 29, 2011 | 07:17 PM
bismic's Avatar
bismic
draboo -
email sent
Old Nov 30, 2011 | 07:43 PM
LSAtexan4x4's Avatar
LSAtexan4x4
hey bismic can you shoot me that email too?
Old Nov 30, 2011 | 08:00 PM
bismic's Avatar
bismic
Sent it your way - let me know if the info helps.
Old Nov 30, 2011 | 08:17 PM
wulfman's Avatar
wulfman
Draboo if i were you i would just do a distilled water flush and not use a chemical cleaner. Sometimes they break stuff lose and help clog the oil cooler some , your temps aren't bad so just flush with water and new coolant. JMHO
Old Nov 30, 2011 | 09:02 PM
draboo's Avatar
draboo
Originally Posted by bismic
draboo -
email sent
got it. Thanks,eh?
Old Nov 30, 2011 | 09:06 PM
draboo's Avatar
draboo
You know, that makes sense right there. I just may try that
Old Dec 1, 2011 | 12:26 PM
droffan's Avatar
droffan
me too bismic, thanks.
deansplace2010@hotmail.com
Aune163rd
Apr 28, 2015 02:36 AM
f350fixaliter
Jul 29, 2012 08:23 PM
anassar11
Apr 5, 2012 01:46 PM
JonArmy
Oct 27, 2011 02:36 PM
chromedom
May 19, 2010 12:19 PM
