pullin the bed ,HELP
Old Nov 26, 2011 | 06:07 PM
danr1's Avatar
danr1
Originally Posted by F350Kid238
i think i am going to try to get a grinder in there and cut a hole in the support of the bed so i can get a pair of vise grips on the bolt in the support then wrench it then i can weld it back up when i get the bed off.
I considered suggesting that but didn't think you'd be willing to cut into support. I know i wouldn't just to save on a little bed lining, not on a good solid bed to start with.
That and the heat created welding in the patch might tend start coating on fire if work to fast doing so. One little tack here and there at a time skipping around to keep heat down isn't best way to produce a good solid weld/repair. Body panel patch yea but not structural such as that will be.
Old Nov 26, 2011 | 08:30 PM
F350Kid238's Avatar
F350Kid238
ok well i got another one off with my dad just used a flat bar and put a little tension on the bed and it came off but the other one we tryed drilling a hole through the support through the bolt with a small bit then we put a tiny screw driver through the hole but the nut just snaped off the bolt.
Old Nov 26, 2011 | 08:37 PM
abranz's Avatar
abranz
Funny, my son and I removed our 90 bed today. All the bolts spinned and the nuts were frozen. I welded a 1/2 nut to the bolt tops in the bed the could remove the nuts. Two bolt broke but got 4 out this way. Salt does a number on iron. Anthony
Old Nov 26, 2011 | 08:41 PM
F350Kid238's Avatar
F350Kid238
oh that sucks Anthony hows the frame etc look rust wise? im waiting for a buddy to come over to help me lift it off so i havent seen mine yet
DrCharles
Mar 23, 2018 09:29 PM
Built_Ford_Tough_757
Feb 25, 2015 06:15 PM
WilleyJoe.62
17
Oct 9, 2012 07:07 AM
frdf250
Nov 12, 2009 03:57 PM
wilson3821
Jul 13, 2003 03:02 PM
