Removing Bed - undercoating
Old Nov 11, 2009 | 10:19 PM
frdf250's Avatar
frdf250
Hey guys just seeing if any of you have done this before.
I want to remove my bed to undercoat and paint up the frame before winter season.
Ive done a little research and looks like i need torx "sockets" for my impact driver. if these bolts are pretty well rusted on there should i replace them with OEM bolts of will any rust proof ones work?
just looking for some input on what you guys have done/tried.
Old Nov 12, 2009 | 06:53 AM
Billyclub's Avatar
Billyclub
No need to replace them. Just add a small amount of antiseize to them when reinstalled. I've been spraying bed liners for awhile and never had any back out. Just becareful not to strip the heads when breaking free the bolts. Back off the pressure on your air gun otherwise you will either snap the torx bit or bugger up the head of the bolt.
Old Nov 12, 2009 | 07:35 AM
rat49f6's Avatar
rat49f6
Phil Pm me ur address ill mail u some brand new bed bolts i have.
I did my frame with undercoat when i installed my 08 bed, we used a spray gun that goes on the undercoat can. The gun has a name but i cant remember it...same one is used for undercoat. All i know is it def went on better than the rattle cans do.
rat49f6's Avatar
rat49f6
Old Nov 12, 2009 | 03:45 PM
camodown's Avatar
camodown
schutz gun for undercoating seems to work well... Make sure you use a quality undercoat, I have had the cheaper stuff either turn white and peel off, or absorb water and cause rust.
Old Nov 12, 2009 | 03:57 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Great Offer Jim, another example of the brotherhood!
Tdog71
Aug 11, 2013 08:23 AM
xmontex4
Oct 2, 2011 11:02 AM
erichy
13
Mar 4, 2011 11:50 AM
Stockdale Dave
16
Apr 25, 2009 08:23 PM
Longneck
Jan 28, 2003 08:04 PM
