Going to arm chair it, make sure your secondary fuel filter bowl is filling with fuel and do you have an early or late 2004 build? The ICP (Injection Control Pressure) sensor will be located under the turbo on an early build, right hand (passenger side) front valve cover on late build.
When you pull the cap fuel will be there, have someone turn on the ignition to run the pump while you watch.
" if i do that is fuel going to shoot at my face... i know this is a dumb question but i dont fell like going to the hospital tonight i have to work in the AM....
Safety first but you get the idea.... have someone assist you to make sure the secondary fuel bowl is filling. After that I am exhausted for ideas to give you. Usually a no start condition the first known issue is the ICP sensor failed, you can disconnect it to let the program fault, but you are showing no codes at all for any possible combination.
