EBV unpluged = check engine light
Old Dec 1, 2011 | 09:04 PM
fordpride's Avatar
fordpride
Yep They have AB injectors 120cc
Old Dec 1, 2011 | 10:36 PM
Ford4Life7.3's Avatar
Ford4Life7.3
So stage 1's stock.
Old Dec 2, 2011 | 04:31 PM
Powerstroked XLT's Avatar
Powerstroked XLT
Reporting Back:
Plugged in the exhaust back pressure valve terminator plug from DFUSER, pulled my #9 (20 amp MAXI fuse) fuse under the hood to re-set the CEL soft code, fired her up...............no more CEL light
On a side note.....anybody having trouble viewing the mobile FTE website?, it hasn't been loading on my phone
Old Dec 2, 2011 | 07:28 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Originally Posted by Powerstroked XLT
Reporting Back:
Im a little confussed: Did you buy this: 94-97 Exhaust Backpressure Terminator Plug
N.º de artículo EBVT?
and where did you installed, in the connector near the turbo or in the connector to the EVP sensor?
Old Dec 2, 2011 | 11:31 PM
Powerstroked XLT
Sorry for the confusion...
Yes, I bought the Exhaust Backpressure Terminator Plug and connected it to the wire harness plug that typically connects near the turbo. The terminator plug allowed me to run with sensor disconnected and turned the CEL off.
Old Dec 3, 2011 | 06:03 AM
DRRXR's Avatar
DRRXR
Arrow
Now maybe I too be in the woods.
The pic I posted before has it plugged into the connector of the sensor attachment, not the regulating output end that modulates the EBPV.
Its the sensor end that needs to send the false signal back.
HERE IS THE PIC AGAIN--------------------------
Avp09821
6.7L Power Stroke Diesel
Mar 31, 2022 07:46 PM
RubenG
Mar 3, 2019 12:41 AM
Picton
6.4L Power Stroke Diesel
Dec 8, 2017 04:21 PM
plankofwood64
1997 - 2003 F150
Oct 8, 2007 02:52 PM
Kerry
Aerostar
Sep 2, 2003 11:57 PM
