Changing ICP Sensor
Old Apr 8, 2012 | 12:48 AM
RubenG's Avatar
RubenG
Changing ICP Sensor
I got the P2285 Code today so decided to take it to the dealer and see what they said. Well they quoted me $459.99 for the ICP Sensor and Pigtail with 3 Hours Labor, later they told me that they would lower it to $413.00. I thought that was way to much and decided to try to change it myself or take it to another mechanic. I got the following part number
ICP Sensor
3C3Z 9F838 EA
Pig Tail
5C3Z 12224 A
Dealer wanted $160 for the ICP Sensor alone, what are your recomendations on where to purchase this? Ebay has some ranging from $50 - $170. Also since my Excursion is an 04, I am not sure if it is the early model or late model and also not sure where the ICP Sensor it at. Which brings me to the pictures below.
Located where the arrow points
I find this
I am not sure if that is the ICP Sensor, reading the tech folder and other threads I was lead to this spot on the engine.
I think this is where the ICP Sensor is.
Closer look
So how difficult will this be and are the part numbers correct? Just want to make sure. Also am I right as to the location of the ICP Sensor with the 3rd and 4th picture?
Thanks, and sorry for the long post.
Old Apr 8, 2012 | 01:00 AM
BLADE35's Avatar
BLADE35
First pic you posted was the EBP Sensor
Now Being an 04 theres 2 possible locations
1.Under turbo in Back
2.Being in the Passengerside Valve cover
Depends on build Date
I cant tell for shure on your But your ICP Sensor looked to be In the Rear Under the turbo the FUN ONE
Your Last Pic is pointing at the IPR Valve but early models have ICP right next to it just like my pic Lower
Im Not 100% shure so Definatly check the Passenger side valve cover First
William Did a Great writeup on the one under the turbo its in the Tech folder So give him some REP Points
Heres a Pic of the Early one with the junk out the way Due to the Price you were quoted this is where I think yours is at but DEFINATLY Check PASS Valve Cover first
Old Apr 8, 2012 | 01:17 AM
BLADE35's Avatar
BLADE35
I fixed it this pic bugged me for awhile too hard to read it
Old Apr 8, 2012 | 01:38 AM
BLADE35's Avatar
BLADE35
Redirect Notice
Or here^^^^ right where the Green hose is conected to valve cover
Old Apr 8, 2012 | 10:29 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here is where it is on a "late" build. Right near alternator.
And here on an "early" build.
Old Apr 8, 2012 | 04:50 PM
RubenG's Avatar
RubenG
Thanks for the replies. I definatly think that the ipc is in the rear behind the turbo, lucky me I guess . Do you know of a good reputable place to purchase the IPC? I am not sure if I should get the $50 one from ebay or just buy the dealer one? Are all IPC Sensors built the same? One thing I dread is splicing into the wires. Also how can I confirm the part numbers is what I need, I check fordparts.com and I am given two part numbers.
Old Apr 8, 2012 | 04:56 PM
BLADE35's Avatar
BLADE35
IDK about the ones off E-Bay
try this Tousley Ford Parts Depot seem to be fairly cheap
first number ford second number International if you have an International by you they are usually cheaper
<TABLE style="WIDTH: 438pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=584><COLGROUP><COL style="WIDTH: 221pt; mso-width-source: userset; mso-width-alt: 10788" width=295><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 585" width=16><COL style="WIDTH: 110pt; mso-width-source: userset; mso-width-alt: 5376" width=147><COL style="WIDTH: 95pt; mso-width-source: userset; mso-width-alt: 4608" width=126><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 221pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 height=17 width=295 align=left>03 ICP - 04 (pre 9/23/03)</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 width=16></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 110pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl66 width=147>3C3Z-9F838-EA</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 95pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 width=126 align=left>1845274C92</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 343pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=458><COLGROUP><COL style="WIDTH: 221pt; mso-width-source: userset; mso-width-alt: 10788" width=295><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 585" width=16><COL style="WIDTH: 110pt; mso-width-source: userset; mso-width-alt: 5376" width=147><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 221pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 height=17 width=295 align=left>Early ICP pigtail / connector (and EBP connector also)</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 width=16></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 110pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl66 width=147>5C3Z-12224-A</TD></TR></TBODY></TABLE>
Old Apr 8, 2012 | 05:09 PM
2006powerstroke90's Avatar
2006powerstroke90
I bought mine off eBay for like 42$ brand new. It worked great.
Old Apr 8, 2012 | 08:19 PM
BLADE35's Avatar
BLADE35
there you go
Old Apr 9, 2012 | 12:02 PM
mmenzies's Avatar
mmenzies
For parts, my first call is to Rockauto.com. If it is something that they dont carry its Fordpartsguyed, or tousley ford for genuine ford parts at considerably less than MSRP. If you are in a burning rush for same day parts then its the local dealiship at MSRP.
Mark
Old Apr 9, 2012 | 12:15 PM
RubenG's Avatar
RubenG
Mark
Thanks, I'll check them out too.
Old Feb 22, 2019 | 10:48 PM
Jeff Langston's Avatar
Jeff Langston
Icp
is the icp on the valve cover in the 06 f550
Old Feb 23, 2019 | 04:49 AM
bismic's Avatar
bismic
yes .
Old Feb 23, 2019 | 08:41 AM
87crewdually's Avatar
87crewdually
Like already said but I like pics, Front top of the passenger side valve cover is the ICP sensor.
Old Feb 23, 2019 | 08:49 AM
SmackDaddy's Avatar
SmackDaddy
Either sensor will work but will give you different voltage readings if I remember correctiy. DTR recommends using the later style because of a lower faikure rate. $40-60, buy the Motorcraft part or you might regret it.
2003-early 2004 under turbo:
Drain a couple gallons of coolant. Remove degas bottle. Remove FICM. Remove rear stud on intake manifold so it doesn’t tear your arm up. Use a socket, swivel and extension to get it loose.
Late 2004-on easily removed on passenger valve cover. I forget the socket size but think it is a 15/16” deep
