Strange starting problem
Old Nov 22, 2011 | 08:10 PM
amiller609's Avatar
amiller609
Exclamation Strange starting problem
2003 F250 4x4 7.3l Power Stroke....
Starting last week it decided it wanted to be cranky when I would go to start it the starter would turn the engine over 1-2 times and then disengage (it would keep spinning tho) so I figured it was the solenoid on the starter. Picked up a new stater today and installed NOW I turn the key and nothing happens, keep trying and it will crank off like normal. So went back over all the connections on the starter and the ground posts on the batteries (the only things I messed with) everything is tight and clean!!!
Could I have gotten a bad starter? Or am I overlooking something....
Old Nov 22, 2011 | 09:24 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
I would take it back n have them test it. I have had experience with the starter being loose n not wanting to start.
Old Nov 22, 2011 | 10:51 PM
brian42's Avatar
brian42
Veteran: Navy
X2 on the bolts. My starter bolts started backing out on me. Luckily I happened to notice it when I was under there for something else. Some blue Loc-Tite and they've been good since (although I still check them when I slide underneath just to make sure).
Tyler S
27
Jun 19, 2015 09:09 AM
1975FordF250
May 17, 2014 09:32 AM
El Padrino
17
Mar 9, 2013 08:25 PM
erik_bishop
Oct 22, 2008 11:09 PM
62Cole
16
Jul 2, 2006 03:19 AM
