Sponsored by: Auxito
2002 f150 making a "clunk"
Old Nov 22, 2011 | 02:57 PM
rhw125's Avatar
rhw125
New to the forum. ive done research but can't figure this one out. i have the 5.4 4x4 with 127xxx miles. This clunk i feel seems to be from the rear end. Its almost like i hit a small pothole in the road. its not consistent. it does it whenever it feels like it. it does it in 2 and 4 wheel drive as well. it seems to act up bad when im cruising at a constant speed or when i let off the gas then reapply. I've heard ford has *****ty torque converters... i don't know if thats the problem. i think it might be the rear end, a u joint on the drive shaft, or a bad wheel bearing? any help is much appreciated!
Old Nov 22, 2011 | 04:13 PM
00GT's Avatar
00GT
Sounds like the slip yoke needs to be greased.
Old Nov 23, 2011 | 09:03 AM
LLADNAR's Avatar
LLADNAR
Pull the driveshaft, check the u-joints and while you are at it check the input flange on the rear diff make sure it isn't loose. If it is real loose it should be obvious because it will have ruined the seal and it would be leaking alxe fluid everywhere
Old Nov 23, 2011 | 09:08 AM
phil6608's Avatar
phil6608
The pinion bearing may be bad also.
I had that happen to my truck,and it started as a clunk and went to a bang. ):
Old Nov 23, 2011 | 09:23 PM
rhw125's Avatar
rhw125
I just checked the u joints along the driveshaft yesterday.... wasn't that. Whats this about a pinion bearing and where is that located?? my next check is wheel bearings. Another note, its doing it REAL bad in 4x4 and is almost non-existent in 2 wheel drive....
Old Nov 23, 2011 | 09:52 PM
phil6608's Avatar
phil6608
Pinion bearing is in the front side of the rear diff.
Here's some good pics of the rear-end assembly.
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
Old Nov 23, 2011 | 10:17 PM
rhw125's Avatar
rhw125
All i can say is wow... i really appreciate the help fella's. ill keep looking into it as i get time and keep you posted.
muddingmcdude
17
May 10, 2010 04:10 PM
sticks25
1978 - 1996 Big Bronco
May 16, 2008 10:30 PM
bc56845
Mar 15, 2007 09:20 AM
RODNEY,G
Feb 4, 2004 06:49 PM
flyvee1
May 17, 2003 10:00 AM
