hey all you ford guys ..i need help i just bought an 88 ford f150 4x4 and was told it had a bent drive shaft , got new drive shaft and had it ballanced .new joints and trans yoke ..
still got the shakes starts at around 45 mph and only gets worse at 65 to bad to drive it ..
HELP thanks
Rodney/jugsnlugs motorsports
ok yes i did check tires and dont feel bad about askin either .. i know how stupid ppl can be ..
ok . yes it is rear shaft and ive replaced the yoke and took shaft to a good driveshaft man i know .. it was less then 10thousandth run out witch is better then most factory shafts .
ive spoken to soom ppl i work with and they told me to look at yoke on rear end and see if it may be loose .
the guy i got the truck from drove it this way for a while and may have shook it loose ..
no there is no carrier bearing . its a slip in yoke into the transfer case .
ive noticed that both the transfer case and rearend seals are leakin pretty bad so while i got it apart changin seals im gonna change yoke on rear . ty for your quick and informative responce . it is greatly appreciated .
Rodney/JUGSNLUGS motorsports
Rod....sometimes a u-joint will be bad and its hard to tell. push on the thing real hard up and down.& side ways, must be in neutral where there's no strain or load on it. also u joints can pop or a snap like noise when shifting forward or reverse from stop. u may find alll those needles are worn and dry and maybe rusty. paul..
I have a similar problem that occurs around 70 - 75 mph. Have also replaced joints and had the d/s balanced. Tires/wheels have been ruled out.
I'm down to either the pinion flange or the tailshaft housing. I'm going to replace the tailshaft housing because there seems to be a good amount of play in it.
I've heard that the long single shaft drivelines will wear out the housing bearing especially when a vibration is present.
thanks dan ..
ill let ya know if it works im gonna start friday night the 6 and i aint commin outta the garage [except to test drive ] till its fixed i got both pieces and am really wanting it fix .. it sucks drivin 50 mph all over .lol
and thanks for all the posts concernin my prob . its good to see that ppl are still willin to help a lil ..
