I have a 2011 F350 4x4 Diesel and would like to gain approximately 2-3 inches in height and continue using the factory 20 inch wheels (merely for looks). The local shop recommends a Level Kit using spacers on the springs. I don't want to sacrafice the ride quality due to the fact it is a daily driver. I also may be pulling a fifth wheel in the near future. I don't mind doing it right and forking out whatever funds are needed, however, the truck doesn't climb rocks and I am somewhat opposed to replacing items needlessly, any thoughts?
Been working on the same thing. My business partner has on '08 with front spacers and 350 blocks in the rear. Rides as good as my stock.
There are some real thorough kits out there. Front spacers, drive shaft spacer, shock mounting bracket extensions, bigger rear blocks. Don't forget you'll want something that relocates the stop blocks and a front end alignment when all done.
