Sponsored by: Real Truck
1" leveling kit
Old Oct 3, 2006 | 12:33 AM
nvrenuff's Avatar
nvrenuff
1" leveling kit
Anyone know of a 1" leveling kit for an 06 F350? and can I add this to a 4" suspension lift kit in the front to level out the truck without any adverse effects to handling etc?
Old Oct 3, 2006 | 12:47 AM
RACERX7775's Avatar
RACERX7775
1" kit?? if you get a 4" lift kit, it will be 4" front and 2" rear. thats how the truck will get level when you buy the lift.
Old Oct 3, 2006 | 01:49 PM
nvrenuff's Avatar
nvrenuff
The 4" kit is already installed, but it does not sit level, with the add a leaf it came with for the rear, it sits too high in the rear for my tastes. My options are to remove the stock 3 5/8" block and replace it with a 2.5" block, or as the original question states, add a 1" spacer to the front and go get an alignment.
I would rather lift the front if possible than lower the back and am looking for some info on whether someone makes a spacer for the front or if its even possible.
For whatever reason, my truck sits higher in the rear than my buddies identical truck with the identical 4" kit, go figure. I installed them both too.
Old Oct 3, 2006 | 02:09 PM
biz4two's Avatar
biz4two
Arrow
IMO...you are probably going to replace the rear blocks (as you stated in a previous post). The only leveling kits for the 2006 SD's...is the 2" or 2.5"...that I could find. No such 1" kits...
Good luck...
biz
