Leveling Kit vs. Lift
Old Nov 2, 2006 | 09:12 PM
PowerStrokeMe's Avatar
PowerStrokeMe
Truck is an 00 F250 PSD 4x4. Front and rear springs. I need new shocks and was also thinking about a mild lift. I know some people have done the 2.5" Leveling kit from RC. I was thinking maybe a 3" lift. Something Mild...I only have 285s. What are some of my options?
I found this.....Only thing is it is extended hangers and I have heard those aren't a good way to go.
http://cgi.ebay.com/ebaymotors/99-04-FORD-F-250-F-350-FORD-SUPER-DUTY-LIFT-KIT_W0QQitemZ230046234730QQihZ013QQcategoryZ33585Q QrdZ1QQcmdZViewItem
Any kits that give 3" with add-a-leaf or replace spring packs with shocks? I think 4" would be too much.
What if I did the leveling kit with new rear shocks and went up to the F350 blocks? That way when I do tow it doesnt sag?
Old Nov 2, 2006 | 09:19 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Well if your truck sits level how you like it now, then a levelking kit alone will give a sag-azz look. The RC leveling kit (i have) and the 4" (3.5") rear blocks will give a nice 2" lift and will still keep axlewrap to a minimum. If you are loaded and have sag,then you can do an add-a-leaf to increase capacity. Don't do add a leaves all the way around. I rode in Jtharvey's truck with all four corners done and boy was that a harsh ride.
Old Nov 2, 2006 | 10:48 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Whatever you do, don't get the sag-azz look. That seems to be a BowTie thing and I think it looks retarded and therefore appropriate on a Chevy.
Old Nov 2, 2006 | 11:17 PM
PowerStrokeMe
Thanks Kris. I want the truck to be up a little more in the air is all, not much more. So what you are saying is to do the RC Leveling kit and get the F350 rear blocks and U bolts then? If I put another leaf in the rear springs, would that help with axlewrap? I hardly tow much except the quad, but no big trailers or campers....yet
I thought you put a different lift on your truck...or were your stock wheels that small Just kiddin.
I was thinking that would probably get me to where I want to be. Anybody else done this? Any pictures??
LOL I agree Tenn...I dont want the sag-azz look either
Old Nov 2, 2006 | 11:58 PM
DavidT.'s Avatar
DavidT.
Old Nov 3, 2006 | 06:15 AM
PowerstrokeJunkie
Well, i had a leveling kit and 33's. Then i added a 4.5" spring hanger, and then i just added my new wheels and tires, so it finally looks right.
Old Nov 3, 2006 | 09:24 AM
pbr man's Avatar
pbr man
I have the Tuff Country add a leaf kit on my 350. It raised the front 1.75'' which is just about right, because now when I load it everything sets level. The ride is very good, not mushy like before. If you can get some 350 rear blocks and and this kit I think you will like the results. I was able to put 315's on without any problem.
<CENTER></CENTER>
Old Nov 6, 2006 | 09:09 PM
PowerStrokeMe
I do like that...thanks! Does anyone have the Rough Country kit with Hydro 8000 shocks and like the way those ride?
What about steering stabilizer? Track bar bracket? bumpstops?
Did anybody replace theirs?
I found a kit from rough country with all new front spring packs, dual front 8000 shocks, dual steering stabilizer, and rear shocks for $660 shipped.
Other one I found is new packs with single front shocks for $340 (I still need rear shocks though) so probably add another $85 onto that so around $425.
I guess is the dual front shocks and stabilizer worth the extra $200+??
Old Nov 6, 2006 | 10:33 PM
powerstroker27's Avatar
powerstroker27
<CENTER></CENTER>
do you have any rubbing issues at full turn or at full compression with that set up?
Old Nov 8, 2006 | 01:28 AM
pbr man's Avatar
pbr man
It rubs a little on the inner plastic wheel well liner. I took the factory splash guards off and used ones that fit flat in the wheel well and that gained me a litle more clearance.
Monsta
Oct 1, 2008 03:00 PM
96sherm
24
May 19, 2007 10:34 AM
Stryker472
1997 - 2003 F150
15
Mar 1, 2007 12:24 AM
bigsexy63
Offroad & 4x4
Feb 14, 2007 03:02 PM
pmbarber
2004 - 2008 F150
17
Aug 1, 2005 10:17 PM
