Frame swap question
Old Nov 21, 2011 | 01:38 PM
Sprout22's Avatar
Sprout22
Frame swap question
Will my 70 truck work on any of the dent truck frames?
Old Nov 21, 2011 | 02:51 PM
HIO Silver's Avatar
HIO Silver
Yes BUT, you really need to read this write-up: Chassis Comparison - '67-'72 vs. '73-'79 - FORDification.com
It should answer your questions
Old Nov 21, 2011 | 02:58 PM
jowilker's Avatar
jowilker
2wd drive chassis are pretty much the same from 65-72. You should be able to direct swap between those with no issues.
In 73 Ford added 4" to the rear of the cab behind the cab mounts adding the length under the bed. One can use the 73-79 chassis in a swap but will have to deal with the 4".
John
Old Nov 21, 2011 | 03:03 PM
Sprout22's Avatar
Sprout22
Thanks for the info. That helped a lot.
Old Nov 21, 2011 | 04:11 PM
elgemcdlf's Avatar
elgemcdlf
The article left out another option for the 2" that needs compensated for. Put the outer skins from the bump on the dent box adding 2" to the front. It would be another virtually unnoticable. If me I think I would split the difference as in the first option listed. You can play with wheelbase a bit without anyone noticing. I lengthened mine when I did the suspension swaps to get a little bit better ride. Longer wheelbase gives a better ride. I didn't add much but I did add to it. About an inch to the front and another 1/2" or so to the rear.
Old Nov 21, 2011 | 08:42 PM
Sprout22's Avatar
Sprout22
hey guys, thanks for all the info but i think it too much work for me. lol. I only asked because I can get the dent frame a lot easier than i can find a bump frame. Guess i'll jus keep lookin for a bump. thanks guys
Old Nov 21, 2011 | 08:50 PM
elgemcdlf's Avatar
elgemcdlf
Where are you located?
Old Nov 21, 2011 | 08:54 PM
Sprout22's Avatar
Sprout22
near Charlotte, NC
SquattingBear
Apr 4, 2011 04:00 PM
mjvalle
Nov 11, 2010 11:30 PM
93 mix 'n match
1997 - 2003 F150
Apr 6, 2010 08:45 PM
robnordmann
Jul 7, 2005 06:08 AM
bigblock466
Oct 18, 2004 04:41 PM
