Sponsored by: Auxito
oppertunity for a SWEET swap!
Old Apr 5, 2010 | 09:08 PM
93 mix 'n match's Avatar
93 mix 'n match
today i was at a great junkyard and i found the best deal ever! a 98 f250ld!
i was wondering....could i swap the parts off the 250 onto my 150? rear axel(big ol girl), front assembly etc...
everything to basically make it a 250 suspension wise.
will it all bolt up?
Old Apr 5, 2010 | 09:30 PM
Ultramagdan's Avatar
Ultramagdan
The frame is thicker and stronger on the LD. It would be easier to just put your cab on the LD frame and drive off.
Old Apr 5, 2010 | 09:32 PM
93 mix 'n match
i wish...its a long bed though...
Old Apr 5, 2010 | 09:35 PM
swillett's Avatar
swillett
its not all that tricky to shorten a frame...
Old Apr 5, 2010 | 09:41 PM
93 mix 'n match
maybe i should just buy the hole truck.... id like a longer box...
do all the f250s come with a 5.4?
Old Apr 5, 2010 | 10:37 PM
cogden's Avatar
cogden
Some F-250LD's came with 4.6's.
Old Apr 5, 2010 | 10:39 PM
93 mix 'n match
well it would save me a boatload of time and money i think...i want to do a 5.4 swap....also want the longer bed....
Old Apr 6, 2010 | 09:46 AM
Ron W.'s Avatar
Ron W.
I'm not 100% sure but if the wheel-base is the same between the 2 trucks you should be able to swap the cab and box without having to fabricate. And swaping the cab and box would be less work.
Old Apr 6, 2010 | 04:02 PM
93 mix 'n match
my truck is a 6.6', the 250 is a long box.
Old Apr 6, 2010 | 06:36 PM
swillett's Avatar
swillett
How to shorten a LWB frame - The 1947 - Present Chevrolet & GMC Truck Message Board Network
here is a tutorial for shortening the frame on on old chevy.
it should be a similar project doing a ford
Old Apr 6, 2010 | 08:45 PM
93 mix 'n match
do i have more of a chance of blowing an axle on the trail or bending my frame? all i want are the beefier axles.... will the new suspension components bolt right up?
Biggreen71250
Feb 2, 2015 10:08 PM
factory594x4
Jul 16, 2012 01:24 AM
Fornatic
Aug 12, 2010 10:26 AM
