Lost my brakes
Old Nov 21, 2011 | 06:56 AM
kent521's Avatar
kent521
Lost my brakes
Over the weekend , I was hauling some eqipment and lost the brakes on my truck and trailer . The brake pedal is hard as a rock there for I think thats the reason I had no trailer brakes , but where do I need to start looking to figure whats the cause ?
Old Nov 21, 2011 | 07:42 AM
tshrager's Avatar
tshrager
Most likely the vacuum pump went out. Common problem on these trucks
Old Nov 21, 2011 | 07:48 AM
kent521's Avatar
kent521
If my vacuum pump went out wouldnt other things be affected and not just my brakes
Old Nov 21, 2011 | 08:19 AM
DIYMechanic's Avatar
DIYMechanic
Not really. The only things the vacuum pump really runs on these truck is the brake booster and a couple things on the climate controls. The red "brake" light on the dash will illuminate if the vac pump is out as well.
Not a bad job to replace. If you end up replacing one, make sure you have access to a power steering pump pulley tool so remove and re-install the pulley on the VP. Also, you'll need to put one of the bolt into the pump before you install the pulley, or you will get to practice the removal and installation process again!
Old Nov 21, 2011 | 08:25 AM
kent521's Avatar
kent521
The brake light did come on . What your input on reman pumps or the best brand w/out braking the bank .
Old Nov 21, 2011 | 09:03 AM
DIYMechanic
Everybody seems to have less than favorable luck with the pump that Airtex makes, but then again I have heard mixed reviews on all of them. I would get the best one you can afford since the function of your brakes rests on that pump, but I'm not sure whaich one to recommend. I replaced mine a few months back with one made by either A-1 Cardone or Dorman (I honestly don't recall), and I've had good luck with it so far. I spend around $80 for mine.
fordpride's Avatar
fordpride
The light will not always come on. Change your vacuum pump and you will be good to go.
halaferd
Dec 24, 2011 04:52 PM
Southern Buckers
Apr 27, 2010 08:02 PM
429PI IN 75 f-100
Sep 10, 2009 06:47 PM
ncvan
Dec 21, 2006 01:05 PM
fordff
Aug 4, 2004 12:02 PM
