Bad Vacuum pump or booster?
Old Dec 20, 2006 | 04:48 PM
ncvan's Avatar
ncvan
Exclamation Bad Vacuum pump or booster?
1992 F-250 7.3 diesel
My brakes comes and go ... well when they "go" ... I can still stop the truck, but I have to stand on them. Most times they will be fine and will work. Warning light sometimes comes on, but mostly not.
Had it at the shop, guy took it home, it didn't do it for him.
Hubby had replaced hoses, checked belt (I think), had gauge on it ... would be up around 15 ... Even at about 6-8 I had brakes, but when it went below 5, the "hard" brake was what I had... no power brakes.
So. I have a manual, and it gives a test to determine which is which, but I the results were inconclusive enough to determine pump or booster.
Any ideas?
Old Dec 20, 2006 | 04:49 PM
ncvan's Avatar
ncvan
There's a glitch in the posting program. I cannot get it to print out the word "brakes." The post should say "My brakes (b-r-a-k-e-s) come and go ..." Didn't show up in the first post correctly.
Thanks
Last edited by ncvan; Dec 20, 2006 at 04:54 PM. Reason: post keeps leaving out a word I am typing and see in the preview!
Old Dec 20, 2006 | 05:34 PM
shorthair's Avatar
shorthair
just went through this problem could not get more than 15" of vacuum at 2000 rpm put a reman vac pump on & now have good brakes every time no more brakes once then real hard pedal the next time.
Old Dec 20, 2006 | 06:32 PM
tjc transport's Avatar
tjc transport
i ain't rite
your vacuum pump is bad. it should be pulling closer to 20 inches of vacuum.
Old Dec 21, 2006 | 01:05 PM
gabyski's Avatar
gabyski
Your vacuum should pull 22" to 24" That is what my local ford dealer told me. and that is at about 1500 rpm
