Engine swap
Old Nov 20, 2011 | 10:32 PM
Vinford's Avatar
Vinford
Engine swap
I have a 1994.5 Powerstroke that needs a engine.
I found a 1994 Turbo diesel .
Is there anyway I could put that motor in instead of a Powerstroke?
Would it be possibly and what all problems does everyone think I would run into?
Old Nov 21, 2011 | 12:28 AM
Vinford's Avatar
Vinford
49 reads on this and no ones got a opinion?
Out of 50 guys I should have got at least 10 diffrent opinions ....................
Old Nov 21, 2011 | 04:01 AM
tjc transport's Avatar
tjc transport
i ain't rite
yea, ya could, but if you have an automatic trans you will probably have to change the computer to the idi trans computer.
Old Nov 21, 2011 | 08:11 AM
DIYMechanic's Avatar
DIYMechanic
I think for a swap like that you would have to find a donor truck. I am guessing that you would need the PCM, the engine, wiring harnesses, possibly the motor mounts, and I'm not sure what the tach in an IDI runs off of, but I would think you would have to deal with that as well. Sounds like a lot of work to me.
Old Nov 21, 2011 | 05:45 PM
chicagodragon's Avatar
chicagodragon
The idi only has one wire to run it. The engine mounts are the same. The PCM might need to be changed to make it shift right. All the dash gauges will be wrong. I just put a powerstroke in a idi last summer and tried to see what would work with what
Old Nov 21, 2011 | 09:16 PM
towsrus's Avatar
towsrus
its alot less work and probably less money in the long run just to put another powerstroke in it. plus when you sell a powerstroke obs truck and someone sees an idi in it, it wont be worth half as much
Jeff_Charlton
Dec 25, 2017 08:27 PM
david024
Feb 10, 2017 05:33 PM
Truck Guy99
Engine Swaps
Mar 4, 2013 10:44 PM
BLK SHP
General Diesel Discussion
Oct 22, 2010 01:07 PM
