engine swap
Old Feb 10, 2017 | 02:16 PM
david024's Avatar
david024
engine swap
I have a 1992 f250,2wd.auto ,5.8 , 120,000 miles,rebuilt trans and other new parts.Truck runs solid but was a fleet truck which I drove since new,problem is I have always hated the leg room and std cab..I have found a few ext cabs close to same year with bad motors and/or trans,can someone tell me what years of pu would be a clean easy engine swap.
​​​​​​​Thanks
Old Feb 10, 2017 | 04:20 PM
Lead Head's Avatar
Lead Head
Any year. Just take your bare engine, strip all the electronics off it, and then put all the wiring and electronics from the new truck onto your good motor.
Old Feb 10, 2017 | 05:20 PM
GoinBoarding's Avatar
GoinBoarding
Assuming that you have an E4OD trans that you want to move to the new truck, you'll have to pay attention to solenoid pack compatibility as well if you go to a newer truck (94?+). I'm not certain in specifics but some searching should find the answers if someone else doesn't chime in.
Old Feb 10, 2017 | 05:33 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Stay with a 5.0 or 5.8 truck. Different engine mount brackets with other engines.
TheProfessorofTOOL
1997 - 2003 F150
Mar 29, 2015 01:29 PM
mudbogger93
May 7, 2012 10:12 PM
ziggy857
Jul 9, 2010 10:16 PM
sibernut
Jul 15, 2009 07:42 AM
