429 INSTALL
Old Nov 20, 2011 | 08:09 PM
4020powershift's Avatar
4020powershift
429 INSTALL
GOOD EVENING, LOOKING TO INSTALL 429 INTO '76 F150 4X4 THAT I HAVE PULLED THE 360 OUT OF. WHAT DO I NEED IN TERMS OF MOTOR MOUNTS/BRACKETS ETC. I KNOW I NEED TO CHANGE TRANS TO FIT BELLHOUSING PATTERN, MY TRUCK IS AN AUTO. THE AUTO TRANS THAT IS WITH THE MOTOR IS OUT OF A MERCURY CAR, CAN I USE PARTS FROM MY EXISTING C-6 TO MAKE INSTALL WORK ? TAIL SHAFT ETC. ETC. THANKS YOU GUYS ARE ALWAYS A BIG HELP. JEFF
Old Nov 21, 2011 | 10:20 AM
59flatbedford's Avatar
59flatbedford
Hey Jeff this is Matt (the kid with the engine). Ive been doing some looking also and seen this and figured if nothing else i would bump it back up.
Any how i did a quick search here and it sounds like you should be able to use the motor mount perches from a 4x4 with the 400 engine and they should bolt right in and accept the 429. I would think these should be easy to find, nothing else i might know where i could find a set.
As far as the trans goes i found this thread
https://www.ford-trucks.com/forums/1...-a-4wd-c6.html
and another one
Can you convert a 2wd C6 to 4wd? - Oilburners.net
Asking about the same question and it sounds like it output shafts and tail housing can be swapped but it might require going into the transmission a ways, but it sounds like you have a transmission expert connection so that might not be an impossibility.
Then there would be exhaust and linkage and all that other little stuff that seems to never end. Hope this helps a little. or at least brings it up to the top so somebody that does know can answer.
Old Nov 21, 2011 | 11:23 AM
mark a.'s Avatar
mark a.
You have to take the whole trans apart to change tail shafts, so you might as well do a complete rebuild on it while your at it.
acarter92
Sep 10, 2013 07:20 PM
66gpw
Apr 21, 2012 12:09 PM
Mythic
Oct 7, 2011 07:22 AM
e william
Jan 17, 2010 01:00 PM
colin151
Jul 12, 2007 01:53 AM
