PS Set-up on a 390 FE
I am installing a power steering unit on a 74 F100 with a 390 FE that came with only a one sheave crankshaft pulley and one sheave waterpump pulley.
My questions are:
Do I buy a 2 sheave for the waterpump or crankshaft ?
Can another one sheave crankshaft pulley be bolted to the existing one ?
Thanks
My questions are:
Thanks
My crank, water pump, and alternator have two-groove pulleys. The PS pump is driven by a separate bolt-on pulley bolted in front of the crank pulley and uses a dedicated belt. The pulley behind the fan spacer is supposed to be for an air pump which my rig no longer needs so it is just along for the ride.
Sorry for the rotated pic.
If you don't have a/c then the original setup was a single belt drove the water pump and alternator, and a single belt drove the p/s pump.
Here's a not too clear picture of my original setup.
The alt., water pump and p/s are all single shieve, the crankshaft pulley was a double shieve.
Also, the p/s pulley was different between a/c and non-a/c trucks.
Single belt Crank-Power Steering
Josh
Josh
Meridian_Mike
05-10-2019 07:31 AM
OldFords
04-25-2010 04:51 PM
cbfomoco
11-22-2005 02:28 PM
