Engine removal vs front clip question
Old Nov 18, 2011 | 04:02 PM
Tyler S's Avatar
Tyler S
I have decided to pull my engine (351W) out of my 51 F-1. Should I take off the front clip to do that or should I leave it on? Either way I plan to borrow an engine hoist from a friend of mine (Lorolr on FTE).
If I need to remove it (and sooner or later I will for sand blasting etc.) is there a good exploded diagram anywhere of a 51 front clip? I have the 1944-1952 Ford body parts catalog, but I don't see a diagram of my front clip. I THINK I have body type C81B "DeLuxe Closed Cab (114" and 122" Wheelbase)-Light Duty" but not entirely sure.
I would like to have a plan if and when I remove the clip rather than just laying into it with a wrench and muddling through.
Thanks guys,
Tyler
Old Nov 18, 2011 | 04:56 PM
BigPigDaddy's Avatar
BigPigDaddy
I removed my front clip with a little help from Ilya (51PanelMan).
Here's the info in my thread.
Old Nov 18, 2011 | 06:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
By all means take it off! You don't disassemble it, you just take out the bolts at the radiator support, the running boards, and the cowl, disconnect the wiring, and badda-boom, it lifts off as a unit. You'll never regret doing it. (You will want the hood off too)
Old Nov 18, 2011 | 06:14 PM
topmoo's Avatar
topmoo
It is much easier when it is off, and you can clean it up a lot easier too. You will also have to remove some wiring or unplug it for the lights and anything else you might have on your inner fenders. But worth it when taking out or putting in an engine and tranny.
Old Nov 18, 2011 | 07:44 PM
Tyler S's Avatar
Tyler S
Ok good info. I'll do it. For some reason I wasn't smart enough to look in my shop manual to see how to remove the clip. The procedure is right there, just as you all described. Being inexperienced is tough enough. Inexperienced AND STUPID is even worse!!
Thanks guys!
T
Old Nov 18, 2011 | 07:49 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
I can't count the number of times I've asked questions on here, only to find the answer in the Shop Manual. You are not alone... and you are not stupid. No one here is going to fault you for asking a question. That's why I love this site.
Old Nov 18, 2011 | 08:21 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Tyler I ask questions like that and then forget by the time I really need the info.
Then ask again because I forgot that I already asked...that's when I really expect to get hammered...
Old Nov 18, 2011 | 09:17 PM
Tyler S's Avatar
Tyler S
Lol! So that front piece where the hood latches...it's about a foot and a half wide or so...it comes off with the fenders all as a single unit? I happen to have a small tranny cooler mounted just in front of where my radiator was. Apparently that isn't stock. I'll have to uninstall that too, before the clip. I think I'll put my tranny cooler elsewhere when I rebuild. T
Old Nov 18, 2011 | 10:18 PM
Tyler S's Avatar
Tyler S
Hey big pig! That thread is very helpful. Thanks! Tyler
Old Nov 18, 2011 | 10:54 PM
BigPigDaddy
You are welcome!
GoldCo
Feb 12, 2016 08:55 PM
2002fx4122
Oct 1, 2010 03:36 PM
Victor L
May 3, 2010 11:32 AM
sinstr_shadow
Jun 3, 2009 06:35 PM
fordxxx
Feb 28, 2003 11:02 AM
