Running boards lights...
Old Nov 17, 2011 | 05:47 PM
12amracer's Avatar
12amracer
Mine are out and ive searched and found that those lights have a 10a fuse under the hood. Even the manual I've downloaded verifies this. Apparently it's the fuse box next to the distribution box. In my manual it shows that there are 6 mini fuses of different amps in this box. But in mine there are no mini fuses, only square black ones and it's a total of like 10. In the manual it shows fuse number 3 for the cd player, but when removed the cd keeps playing so I know I'm in the wrong place. I know this is so simple I'm making it hard, but any help is appreciated. 98 gator.
Old Nov 18, 2011 | 08:52 AM
c_hohensee's Avatar
c_hohensee
Do you have one more box farther into the corner? There is a total of 3 boxes on the expy, likely the same on the gator.
Old Nov 18, 2011 | 09:32 AM
12amracer's Avatar
12amracer
Man, Thanks!! I really do not know if I would have ever spotted that thing seing as how its flushed with the sidewall and half an inch wide! lol
Too bad the fuse was good tho . With the interior lights on and all 4 running board lights out I just knew it was the fuse! oh well I found a ton of threads about replacing the bulbs, might as well go back and find them. Thanks again!
Old Nov 18, 2011 | 09:57 AM
alwaysfords41's Avatar
alwaysfords41
Have you checked the dimmer switch? It is a common thread between all the lights you mention being out.
Old Nov 18, 2011 | 10:16 AM
12amracer's Avatar
12amracer
I checked the dimmer switch it works. To clarify, my interior lights do work, it's just my running boards that are out.
Old Nov 18, 2011 | 01:12 PM
alwaysfords41
My misunderstanding. I'd check the voltage at a socket on the running board then.
Old Nov 18, 2011 | 05:22 PM
pdqford's Avatar
pdqford
That mini fuse supplies power to the Running Board Lamp Relay. It is located above the glove compartment and the passenger side air bag.
Should be a black/16pin connector under the air filter box which is between the relay output and the RB lamps. Pin 7 (white with red stripe wire) should be hot when the relay pulls in.
The RB lamps share a ground with a number of items that you don't seem to be having issues with. And having all four lamp sockets go bad at once is not typical.
Old Nov 18, 2011 | 07:30 PM
12amracer's Avatar
12amracer
Thanks for that bit of info! I'll give it a go in the morning. Now how do I get to those relays, let the glove box down? (this is inside the truck correct)
jhcorley
Aug 25, 2020 06:49 AM
turboboost
Jun 15, 2010 11:18 PM
bowhunt24
2004 - 2008 F150
Dec 11, 2009 10:48 AM
HeaVEEweight
May 26, 2009 11:25 PM
CobraGT40
Aug 2, 2008 12:50 PM
