trans in or out?
Old Nov 17, 2011 | 10:28 AM
fordboy300's Avatar
fordboy300
trans in or out?
Just looking for some pointers before I pull my 300 would it be better to leave the tranny in or to pull the tranny with the engine on it? I'm all for leaving the trans in becuz I won't be doing nothing to it beside switch the clutch on it.
Thanks in advance
Old Nov 17, 2011 | 11:59 AM
AbandonedBronco's Avatar
AbandonedBronco
I had no problem at all removing the engine with the transmission still in the vehicle. Be sure to have a clutch alignment tool on hand before putting it back together though.
Old Nov 17, 2011 | 01:12 PM
fordboy300's Avatar
fordboy300
Thanks AB, from where did you hookup the chain from!?
Old Nov 17, 2011 | 01:15 PM
AbandonedBronco
On the driver's side, I bolted it to where the coil mounts. On the passenger side, I used one of the intake/exhaust bolt holes. I removed the manifolds before pulling it. I know some leave them on, so if you do, you may have to find somewhere else.
Old Nov 17, 2011 | 07:28 PM
fordboy300's Avatar
fordboy300
sweet thanks dude!! another question probably not the most intelligent one but do i need a cam degreeing tool??
Old Nov 17, 2011 | 08:56 PM
AbandonedBronco
I think that completely depends on which cam you get.
When I did mine, which was a Comp 260, the cam gear went on ONE way. The crank gear went on ONE way. And then there was a dot on each that HAD to be pointing at each other. There was zero chance of screwing it up because you couldn't, unless you purposefully made the dots not point at each other.
Old Nov 17, 2011 | 09:35 PM
F-250 restorer's Avatar
F-250 restorer
I agree with AB. Leave the trans in. And whether you need the cam degree tool depends on the cam; with most you don't need it, but check with the manufacturer.
Good luck.
Old Nov 17, 2011 | 09:37 PM
fordboy300's Avatar
fordboy300
true. i got a crower cam that my machinist recommended me to get but im doing a complete rebuild.... im still thinking of getting the block honed or just leaving it and getting my head ported and throw the cam in it but then again my dad has gotten the 300 rebuilt once already. So im not quite sure what to do? it's tough making decisions.. lol
Old Nov 17, 2011 | 09:47 PM
F-250 restorer
Your machinist should be able to tell you if you need to bore the block, or simply hone it. Measure the bottom and the top of the cylinders, and that will tell you. Always look for the least expensive way to go, provided all the measurements prove that is the way to go.
Go to the machinist. While there, ask if he can show you how to measure the bore. Measure the top, and then the bottom, and if there is a difference, ask his recommendations.
Old Nov 17, 2011 | 09:58 PM
fordboy300's Avatar
fordboy300
Thanks f250 for the input. I'll be sure to do that next week I'm gonna pay him a visit, and ill be sure to ask him that
WesternAuto17
Aug 27, 2009 12:56 PM
ALBUQ F-1
May 15, 2007 04:46 PM
chris12
Nov 1, 2005 06:24 AM
he race me
May 8, 2005 10:21 AM
familyman
Oct 27, 1999 06:05 AM
