6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
largest tire size
Old Nov 16, 2011 | 07:36 PM
Headviking's Avatar
Headviking
largest tire size
My neighbour has a 2009 F350 CC 4x4 with 20in rims. What is the largest tire he can put on her without rubbing. He has the stock 20in rims, no lift.
Old Dec 7, 2011 | 10:50 PM
RM2738's Avatar
RM2738
I'm running 35x12.50R22 now. Had to tie back the fender liner a bit though. But no issues rubbing.
Old Dec 9, 2011 | 09:43 AM
p8ntballn2's Avatar
p8ntballn2
no experience yet with this.. but i've been reading a lot of threads lately.. here and other forums.. most guys seem to be getting away with 35x12.5x20's... but they rub at full steering lock.. rubs on the radius arms.. not a big deal to me.. but i'm about to put on a 3.5" leveling kit and 37x13.5x20.. and i know it will rub on the radius arms.. maybe someone else can chime in that has 35's..
Old Dec 10, 2011 | 10:57 AM
RM2738's Avatar
RM2738
Your wheel offset is what's really going to determine if you rub or not when youre running 35-37" tires with or without a lift/leveling kit. The best thing I did, was chat with the guys at discount tire and other tire shops. They'll tell you what your offset needs to be. I've got toyo M/T 35x12.50R22 on 22x9.50 w/20 offset. I can turn 100% without any rub except the wheel well panel. Easy fix though, just trim or pull back with zip Ties or they make wheel well brackets that pull them back.
stangDiesel
Sep 27, 2018 05:51 PM
Stevie Ray
May 22, 2009 03:59 PM
dew the thunder
Apr 13, 2008 11:03 AM
cm351f
Apr 3, 2008 04:23 PM
shredder
Offroad & 4x4
Feb 29, 2008 12:45 PM
