Offroad & 4x4
maximum tire size?
Old Feb 29, 2008 | 01:12 AM
shredder's Avatar
shredder
Thumbs up maximum tire size?
hi, i have an 06 king ranch f350 and it has 20 inch rims and the stock tires on it.. the truck seems pretty high, but how big of a wheel/tire can i put on this truck without a lift kit? (and without rub)
thanks
scott
Old Feb 29, 2008 | 06:37 AM
kjett's Avatar
kjett
on my 05 F-350 I have just a 2" leveling kit up front and run the Pro Comp Xtreme AT's in the 325/65r18 flavor on my stock 18" rims. So if you do your conversion math, that makes them 35x13.5x18 tires. I rub slightly on the radius arms, but only a full lock. If you get a narrower tire (like a 12.5 wide), then you should be fine.
Other than that, do a search in the SD forum and this forum, as this has been talked about to death.......
Old Feb 29, 2008 | 12:43 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
thanks
scott
54" thornbirds should fit nice!!!
Old Feb 29, 2008 | 12:44 PM
kjett's Avatar
kjett
I forgot about those. They will fit only with "minor" fender trimming..........
Old Feb 29, 2008 | 12:45 PM
quadzjr's Avatar
quadzjr
thanks
scott
the only answer you need is..........
ROCKWELLS!!!!!
Oscar Giovinazzo
Mar 22, 2015 07:14 AM
Tepot
Jan 10, 2015 05:34 PM
wilbilly216
20
Mar 11, 2010 08:40 AM
XXXcursion
Feb 11, 2003 04:15 PM
siscokidcc
Aug 22, 2002 11:12 PM
