DESKTOP DYNO QUESTION
Old Nov 17, 2011 | 07:14 PM
MIKES 68 F100's Avatar
MIKES 68 F100
HERE'S YOUR NUMBERS SLEEPY
Old Nov 17, 2011 | 07:15 PM
MIKES 68 F100
GRAPH
Old Nov 17, 2011 | 10:11 PM
Rogue_Wulff's Avatar
Rogue_Wulff
WOWZERZ!!! Over 450 Lb/ft of torque from 1000 to 5000 RPM.
I know it's a bit of an "optimistic" program, but holy cow, what a torque bow (can't really call it much of a curve).........
I wonder what a 390, with 9.5 CR and a genuine GT/CJ cam would have with an edelbrock performer intake, edelbrock 600, and flowtech headers.
Old Nov 18, 2011 | 08:47 AM
MIKES 68 F100
any one have the specs off a stock cam for 390 4v or 2v ?
i want to run a 100% stock simulation to see what numbers come up , that should give me an idea of how off the program is .
Old Nov 18, 2011 | 08:51 AM
MIKES 68 F100
sleepy you don't have any compression ratio listed in your specs ,so i guessed at 10:1
Old Nov 18, 2011 | 09:52 AM
MIKES 68 F100
found the stock cam specs and hp ratings
here
Ford "FE" Engine Specifications
Old Nov 18, 2011 | 08:36 PM
MIKES 68 F100
OK ran as close as i could to stock specs for a 67 390 4v (315hp @ 4200rpm)
Old Nov 18, 2011 | 08:41 PM
MIKES 68 F100
so i am thinking it's pretty accurate ?
Old Nov 21, 2011 | 02:46 AM
Sleepy445FE's Avatar
Sleepy445FE
Man I wish it was accurate. 480hp-605ft/lbs would be awesome! Unfortunately real world numbers are more like 450/515. And the peak hp occures at 5100rpm also instead of 4500. The tq bow is pretty accurate just at a higher number. Seems like the dyno reads pretty high on the tq being that the stock 390 shows 450 where as it was rated at 427. It's not too far from stock hp/tq and rpm peaks but most likely gets less accurate the further from stock the specs go.
CR for mine is 9.86:1 btw.
Old Nov 21, 2011 | 09:06 AM
MIKES 68 F100
I'll change the cr to 9.86:1 and see what changes
72Highboy4x4
Apr 9, 2012 10:04 AM
jakeput
Sep 18, 2010 10:23 AM
reed1951
Apr 29, 2008 08:43 PM
tess100
Nov 20, 2004 04:35 PM
1TUFFBRONCO
16
Jun 15, 2004 10:14 PM
