DESKTOP DYNO QUESTION
Old Nov 16, 2011 | 07:13 PM
MIKES 68 F100's Avatar
MIKES 68 F100
Question DESKTOP DYNO QUESTION
I just got desktop dyno 5 sim
is this even close to being close ?
to me it seems to err to the high side and the bigger the carb cfm i go the higher the hp and torq ,
i put in my specs (moderate build )
390 stock bore
10:1 flatop pistons
lunati 62001 cam kit
heads have stock valves and pocket porting
edelbrock performer manifold
holley 600cfm dbl pmper
small tube headers
i'll post a snip of chart later
Old Nov 16, 2011 | 08:17 PM
MIKES 68 F100
HERE'S THE CHART
Old Nov 16, 2011 | 11:39 PM
Sleepy445FE's Avatar
Sleepy445FE
Yeah I'd say it's pretty generous with the numbers. 511tq?! maybe with a 4.25" crank. In Jays book when he ran the Performer on the 445 mule he got a max tq of 505ft/lbs. That's with more cam and heads too.
I'd say take 85-90% of those values as a ballpark figure. 300-320hp 435-460ft/lbs.
I don't know if you're on the other forum or not but you could check your numbers against Werby's Gonkulator. His figures are the closest thing to a dyno you can get. If you find a semi-reliable margin of error between the two, you could nail down future results better.
Lastly.....think you could run the numbers on mine? Specs are in my garage. 2" primary headers open pipe.
Old Nov 17, 2011 | 07:02 AM
Argess's Avatar
Argess
Back when I was selecting a cam for a mild performance build, I called the Crane Tech Line for some cam selection advice. After we decided on a cam, the fellow I spoke to asked for all my engine and carb details and ran some sort of computer program to determine the flywheel Hp.
He got 480 Hp. I suspect this was high too and I'd probably be around 425 Hp based on known similiar engines.
My thoughts on this are the computer program expects perfect ignition timing and perfect fuel mixture. In the real world, these two expectations are probably optimistic.
Just speculation on my part, but I'll stick with that for now as it offers a plausible explanation.
Old Nov 17, 2011 | 07:40 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Exactly. You can put bigger and bigger carbs on an engine, but in the real-world, tuning it is almost impossible to get 100% right.
Also, I'm wondering if they take friction into account. Rings in the cylinder, pistons rubbing the cylinder, bearings, oil pumping losses, the effort to pull air into the cylinders, the effort to push the exhaust OUT of the cylinders, all that takes it's toll.
Old Nov 17, 2011 | 09:44 AM
MIKES 68 F100
YEAH i figured it was off and just a calculated guess , i corrected some of the obvious mistakes
they had ambient temp at 68f i changed it to 80f
i just got it let me play with it and get use to the software
yes sleepy i'll run your numbers i'll post in next couple days
Old Nov 17, 2011 | 10:37 AM
MIKES 68 F100
sleepy what's your guess on c/r for your engine ? also do have a cam card for the cam ? when i entered all my specs off card numbers changed alot .
Old Nov 17, 2011 | 12:17 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Yeah, without all the correct data it's a crap shoot. I do use mine to see what difference changing a part makes, but other than that, put no faith in the numbers. Even real engine dyno's vary greatly. Only true test is a chassis dyno which really crushes ego's.
Old Nov 17, 2011 | 03:20 PM
NW 150's Avatar
NW 150
390 stock bore
10:1 flatop pistons
small tube headers
Hey i don't mean to be off topic here but do you have a clip of your truck running? I'd like to here what it sounds like with that cam.
Sleepy445FE
Here's the link to my garage. https://www.ford-trucks.com/forums/g...eepy445FE.html
Should have all the info you need. I know about what it makes so it'll be interesting to see the difference. Thanks!
Old Nov 17, 2011 | 03:22 PM
mikeo0o0o0's Avatar
mikeo0o0o0
All of this is called "parasitic power loss" that's best defined as horsepower that the engine makes but never makes it out the crankshaft. If you want to see a HUGE parasitic power loss, put a roots style (GMC) blower on an engine.
Old Nov 17, 2011 | 03:25 PM
MIKES 68 F100
VIDEO
******** style="height: 390px; width: 640px"><param name="movie" value="http://www.youtube.com/v/Tcor42VYF9U?version=3&feature=player_detailpage">< param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/Tcor42VYF9U?version=3&feature=player_detailpage" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="360">*********>
Old Nov 17, 2011 | 03:28 PM
NW 150's Avatar
NW 150
dang that sounds pretty good, thanks!
Old Nov 17, 2011 | 03:32 PM
MIKES 68 F100
has very little chop at idle , nice growl when revved , i should have got the 62002 cam in hindsight .
Old Nov 17, 2011 | 03:34 PM
MIKES 68 F100
since video i added a hei distributor , revvs alot faster i think curv of new dizzy is alot better still have to check what spings are in it maybe go lighter springs
