How to: Clean EBPS to gain lost MPGs (Video)
#47
I use what ever the specs call for. If I had to guess, I would say that most of the time I use metric.
Actually, when I use wrenches I will often go for a SAE because I have a wider selection of SAE wrenches. Most of my metric wrenches are on the small end.
#48
Yes...HOLY CRAP THIS IS AN OLD THREAD!!
But it was referenced to me because I couldn't find any others with the info I needed. Great video! It is exactly what I am doing along with a couple of other items this weekend.
I have to ask tho....What the hell are you using for gloves? I have bought about 4 different kinds of latex and rubber gloves and I shred them all within 5 min of use. I finally just got mechanics gloves but they can be slight obstacle sometimes depending on what I am doing.
Thanks again for the video! Even if it is 7yrs old
#49
#50
I will check out HD on the way home.
Thanks!
#52
I use nitrile gloves, been using them for many years. Brake cleaner will mess them up pretty quickly, carb cleaner a bit slower. Won't melt them, but they swell/expand and become easier to tear and the stuff permeates them enough to smell it on my skin after I take them off, but not enough that I can feel the stuff on my skin. They hold up to gun cleaners and other medium/mild solvents well. Oil, ATF, diesel, coolant seem to do nothing to them. They're harder to rip than latex too.
When I hit something sharp enough to cut them and me they seem to help clean the part before it enters me so there's less junk in the cut, plus there's no gunk on my skin to get pushed into the cut.
Latex get super slippery when oily, nitrile give better grip than skin on oily and especially coolant covered parts. The Harbor Freight nitrile gloves work fine. I have a friend that's a distributor for industrial safety stuff so I buy Radnor brand from him cheaper than HF.
#53
I use the 7mil nitrile gloves from HarborFreight and they hold up well. The thinner 5mil ones - which are always on sale - tear easily. You can find 7mil gloves for a similar or sometimes better price online, it's just that the HF store is right around the block from my work. The 9mil are great for heavier work. I reuse them often, pull them off leave inside out to dry, then flip'em and blow them up with the air hose to get em back on easier.
#54
#55
P0478 Question after cleaning tube and EBPS sensor replacement. QUICK side note: I’m running Jelli tunes on Hydra, EBPV delete and Pedestal delete. KOEO map, Baro and EBPS all read around 14.
Question is even after replacing sensor and cleaning tube, I keep getting P0478 as mainly a soft code but sometimes shows up as a hard Cade with CEL on. Is this related to the tuner?
What else should I check?
#56
#57
Hi Mark,
Probably should start a new thread.
I did put a new Motorcraft sensor on from RiffRaff.
the problem existed before I replaced the sensor and cleaned the tube which is part of why I did so.
00Dave
16
02-24-2014 12:54 PM
Shake-N-Bake
30
06-02-2012 02:11 PM
