How to: Clean EBPS to gain lost MPGs (Video)
If you have noticed a steady decline in MPGs, the first place you want to look is the Exhaust Back Pressure tube and sensor. Why here? Because its free and easy to fix if it is the problem, and quite often it is.
How to: Improve MPGs on 7.3L Powerstroke - Cleaning EBPS - YouTube |
Another great job Trey, I have seen quite the response to your account through your various outlets!
Originally Posted by BigAlsPSD
(Post 11038678)
good job reps
if only there was a cheaper pipe to use. |
Originally Posted by snakedoc
(Post 11038694)
good job reps
if only there was a cheaper pipe to use. BTW...:-X22 Spooner |
How much MPG improvement have you seen doing this?
I gained 1 mpg when I did it the first time.
Another on the to-do list.
Good video Trey
Tried to rep you |
Originally Posted by timmyboy76
(Post 11039444)
Matt, if one is good enough with the brake hardline pipe bender, i think it can be done along with the single/double flaring tool? Mcmaster-Carr has various tubing/wall thickness, along with "parameters" of its heat content..etc...just a thought.
Very informative. Thanks
Originally Posted by cj45lc
(Post 11041373)
Good video Trey
Tried to rep you
Originally Posted by DISLFVR
(Post 11040618)
Originally Posted by hammer65
(Post 11041479)
Does a clogged tube or sensor cause the truck to run rough at idle? I have a theory that my engine is running rough due to the EBP sensor sending bad input to the EBPV, causing the EBPV to open and close erratically. I'm getting 15.5 mpg on the highway, so my EBP may be fine. Anyone have any input for me?
BTW, good vid I subscribed to your youtube channel. |
Originally Posted by Swimholm
(Post 11041683)
You can test the sensor with an AE or a SnapOn scanner. Or if you dont have one you can do it manually. The sensor sends out up to 5V depending on how much EBP it is seeing. If you test what voltage it is sending, you will know what its seeing as far as EBP. P0470 = EBP sensor circuit malfunction P0471 = EBP sensor circuit performance P0472 = EBP sensor circuit low input P0473 = EBP sensor circuit high input P0478 = EBP excessive during normal driving Sensor Wiring Diagram http://i686.photobucket.com/albums/v...EPAIR/EBPS.png Voltage:Pressure Graph http://i686.photobucket.com/albums/v...REPAIR/EBP.png
(Post 11041683)
Ok, my question then. I have my ebpv disconnected at the sensor on the turbo ped. It is still plausible that i've lost roughly 2mpg from a clogged or dirty ebpv even tho i have the sensor disconnected and inoperative. Would it be worth cleaning? Thanks
