I think I'd have to understand what "draw of the truck" meant. My concern is that if that means what you normally draw, like maybe 35 amps, something would happen that would cause the alternator to need to throw it's max current, like maybe a dead battery. Would that over heat the shunt?
I'd rather size the shunt so full scale on the meter is full output on the alternator. Then you know you aren't going to burn anything up. And, you know roughly how much current you are throwing.
Gary,
If you read that link it shows that it can take 100% (of 200A) for five minutes, 300% for 3 seconds.
The safety factor is there.
It's also a $60 widget, to allow you to keep functional an instrument that Bill points out is wired on the wrong side of the load (draw) anyhow.
Obviously I didn't read the link. Sorry. But, I do want to get the gauges on my truck useful and trustworthy, so will study up on that - after I get one of these trucks running.
