Running Hot
Old Nov 21, 2011 | 05:56 AM
midsouth's Avatar
midsouth
Running Hot
On my 83 f150 5.8L 4X4, I've replaced the temperature sensor, sender, thermostat. The radiator seems to be fine (top and bottom hoses are both hot which shows the water is flowing and the water pump is working). The gauge is still showing that the truck is running slightly below high. What else can I check?
Old Nov 21, 2011 | 08:12 AM
ozark1's Avatar
ozark1
Do a search for my name..and Gary Lewis. This topic was discussed 2-3 months ago. In my case. I had 2 bad senders..both new..out of the box. A Ford sender got the right readings..My truck was like yours..I finally had enough..New 190 Thermostat..3 row radiator and a new clutch fan..Problem solved..There old radiators may look good..But many are partially blocked..Oreilly has a good 3 row for under $200..Gary will probably jump in too..
Old Nov 21, 2011 | 10:54 AM
ctubutis's Avatar
ctubutis
If the radiator is doing its job, the lower hose won't be nearly as warm as the top one.
Old Nov 21, 2011 | 11:22 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Fan shroud, fan and fan clutch(if equipped) in good order, not a flex fan? Some info on this might help.
Old Nov 21, 2011 | 11:43 AM
Franklin2's Avatar
Franklin2
Why do you think it's overheating? Usually there are other signs. Don't waste a lot of money relying on the factory gauge to give you accurate readings. What is "normal"?
Old Nov 21, 2011 | 12:13 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
If it's a factory flex fan, it should be, "OK" to do it's job, if in good working condition, but a fan clutch upgrade is well worth it in my opinion.
Old Nov 21, 2011 | 07:32 PM
Sw1tchfoot's Avatar
Sw1tchfoot
I replaced my thermostat twice, replaced the temp gauge sensor twice, and eventually shelled out about $60 total for a fan clutch. Nothing worked.
Want to know how I fixed the problem? I didn't, I just bought a cheap mechanical temp gauge from Autozone and found out that it isn't even running hot.
Old Nov 21, 2011 | 10:22 PM
81-F-150-Explorer
The aftermarket sending units tend to run the gauge toward the hot side, I have noticed.
Same thing happened to my 1972... Bought motorcraft sender and problem solved with that truck...
napoleankjj2006
Jul 7, 2009 09:53 PM
johnsf
Aug 26, 2006 02:48 PM
fizzdive
May 23, 2005 05:45 PM
Syzle
May 19, 2002 10:49 PM
Dan-79F350
Aug 25, 2001 08:51 AM
