alternator light intermittant
Old Nov 28, 2009 | 08:03 PM
blrman1962's Avatar
blrman1962
Hi guys I have a problem with my alternator light blinks on and off the battery gauge stays at around 16 volts I replaced the batteries around 2 months ago I had 1 bad but changed both batteries. I have also foound that the radio and Acc. stuff sometimes are still powered with the key off I replaced the ignition switch and have found no burnt wires or shorts please helpl this is driving me nuts
Old Nov 28, 2009 | 08:05 PM
87 F-150 I6's Avatar
87 F-150 I6
have you checked your alt?
Old Nov 28, 2009 | 08:48 PM
Visseroth's Avatar
Visseroth
OK, first thing you need to do is check the connections on the alternator. Ensure that there is no corrosion, no damages wires and that the wires are getting excellent connection to the alternator.
Second thing is if you are getting 16v and found no problems with the wires then chances are you have a bad voltage regulator on your alternator and you're at risk of damaging electrical equipment. 16v is a pretty high voltage but bearable. You need about 13.5 to 14.5v, not 15, not 16 and if you reach 18 then you're in the danger zone.
Get that alternator checked out ASAP. Preferably swap it out but I'm betting your voltage regulator is shot.
Old Nov 28, 2009 | 11:09 PM
clintbonnie's Avatar
clintbonnie
You might also check for rubbing of wires on the wire bundle that goes over the driver's side valve cover..
cree92831
18
Oct 9, 2013 03:14 PM
bcaughhorn
Sep 3, 2013 11:45 AM
JE917
Jul 10, 2010 07:27 PM
noel431
2004 - 2008 F150
Apr 18, 2010 02:35 PM
scott7512
Apr 24, 2007 11:12 AM
