Front clip conversion question
Old Nov 12, 2011 | 07:10 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Next weekend I am picking up a 1985 E350 extended full panel van, Diesel.
I'm a huge fan of the 75-78 front clip with the round lights.
What's involved in converting from the 79-91 to the 75-78 front clip?
I know I'll need the lights, grill and lower part under the grill for the flashers.
Do I need to modify anything for the round lights to bolt in place of the square lights on the rad support? Hopefully I don't need to replace the rad support?
Replacing the rad support is impossible as the van is a diesel, and no diesel offered in the 70's so that's out of the question.
Thanks!
Old Dec 16, 2011 | 05:16 PM
IDIDieselJohn
No one done this before?
Old Dec 20, 2011 | 04:50 PM
creativecars1's Avatar
creativecars1
I did the opposite several years ago. I wanted to make a 76 front match my 86 back. Since only the center portion unbolts the rest of the core support is a welded structure. What I did was to pull the grill, bumper,and lower valance. You will have a big square of metal on each side of the radiator opening. I used a donor van and cut the entire flat square area out and did the same on the van I was fixing Then I welded the new pieces in place. It looks factory, with the rest of the stamped recesses in place. As I remember I could not simpully pull the round H/L's out and put the square ones in place, so the metal work was necessary. You may also have to reroute the marker/turn signal wires. Good luck and have a great day.
Old Dec 25, 2011 | 12:50 AM
IDIDieselJohn
Thanks for the reply! Looks like a good amount of work, considering the van isn't worth it all. Oh well, for my next one I guess
Old Dec 25, 2011 | 05:35 AM
JWA's Avatar
JWA
John this was a good idea if only because in the end you'd have what you wanted----sometimes the ideas don't work out.
You'll find something else to get into I'm sure----I know I would!
AliceSML79
Dec 9, 2015 08:23 AM
Wyoming150
1997 - 2003 F150
29
Apr 1, 2009 06:34 PM
reddog3979
1997 - 2003 F150
May 18, 2008 06:58 PM
01silverf150
1997 - 2003 F150
Mar 24, 2006 05:41 AM
Hogrider301
20
Nov 8, 2005 04:22 PM
