Next weekend I am picking up a 1985 E350 extended full panel van, Diesel.
I'm a huge fan of the 75-78 front clip with the round lights.
What's involved in converting from the 79-91 to the 75-78 front clip?
I know I'll need the lights, grill and lower part under the grill for the flashers.
Do I need to modify anything for the round lights to bolt in place of the square lights on the rad support? Hopefully I don't need to replace the rad support?
Replacing the rad support is impossible as the van is a diesel, and no diesel offered in the 70's so that's out of the question.
I did the opposite several years ago. I wanted to make a 76 front match my 86 back. Since only the center portion unbolts the rest of the core support is a welded structure. What I did was to pull the grill, bumper,and lower valance. You will have a big square of metal on each side of the radiator opening. I used a donor van and cut the entire flat square area out and did the same on the van I was fixing Then I welded the new pieces in place. It looks factory, with the rest of the stamped recesses in place. As I remember I could not simpully pull the round H/L's out and put the square ones in place, so the metal work was necessary. You may also have to reroute the marker/turn signal wires. Good luck and have a great day.
