e-150 Check Engine Light
It could be anything. If you don't want to pay the dealer to check the codes, why don't you pick up an OBD II code reader from an auto parts store for $70-100 and read the codes yourself? Once you've got the codes, put them here and people can give you much more precise feedback.
Really, it's the best approach. One trip to the dealer to check codes is going to cost you more than that. If you don't read the codes, you're just going to waste money throwing parts into it until you trip over the actual issue, if you even find it at all.
EDIT: Here, it's $53 on Amazon with free shipping:
http://www.amazon.com/Equus-3030-Inn.../dp/B000EVYGQY
EDIT #2: Once you've got the codes, post them in the 5.4 section of the forum and people can help you there.
https://www.ford-trucks.com/forums/forum48/
The code reader is only $22.00 at Amazon, O'Reilly auto parts also sells them:
Amazon.com: Equus 3145 Ford Digital Code Reader: Automotive
Here is your plug and no adapter needed:
pappyfixit67
10-03-2011 11:33 PM
