I have a '95 150 XLT, with a 351w 2wd. Sometimes when I turn sharp out of or into my drive way or to park (slow), ill get a pretty loud knock in the drivers side suspension. I'm thinking U-joint? But could be a lot of things. What should I look for when I get under there.
OIF Vet: C Co 1/327IN ATR!
I'd be looking at the Balljoints.....Also, the wheel bearings...
Just take a peek, if its the ball joints, you'll see the space between the spindle/balljoint.....It'll be obvious...
While you're under there...A quick squirt of grease wouldn't hurt...To grease everything up....And look into the tie rod ends, etc..
2wd can also have the sway bar. Worn out bushings in that are the leading cause of front end knocks in most vehicles with no other symptoms . Check em if you got em ...
Definitely my radius arm bushing. Its there, but just barely. So i guess i need to go to the advanced auto shop. Thanks the starting point! Everything else looks pretty good. dirty but good. Thanks people!
Just got my Bushings last night at AutoZone for 13.99 for the pair with a life time waranty getting started on the change out here in a few once the shop warms up.
Make sure to check out the radius arm brackets on the frame, too. If the hole for the bushing is worn or they are very rusty, you will want to replace those brackets too.
Its going to take longer than i thought...i have to grind down the stupid rivets that are holding the bracket in place...unless there is another way...
Use a cutoff wheel instead...I usually make a full cut right in the center...And if needed make another....Then simply hammer them out...
