ignition box
Old Nov 11, 2011 | 09:13 AM
Cody_302's Avatar
Cody_302
ignition box
Who else’s ignition box is leaking goo out on top the fender?
Old Nov 11, 2011 | 11:52 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Every one that has one overheating. Space it with washers to allow for air circulation or better yet relocate it to a cooler space. Common problem.
Old Nov 11, 2011 | 02:31 PM
Cody_302's Avatar
Cody_302
thanks. any way to get this crap off my fender?
Old Nov 11, 2011 | 02:38 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Never really tried, but I think it's epoxy. Should chip right off if it's cold.
Old Nov 11, 2011 | 02:47 PM
Cody_302's Avatar
Cody_302
should i expect the one that leaking to fail soon or should i just clean it up and try to reseal it?
Old Nov 11, 2011 | 02:53 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Hard to tell. I have one that was actually leaking the sand like substance under the sealer. I sealed it and it's still working fine after two years. Took me awhile to figure out what was going on. Wasn't melted, looked like an ant hill on my fender. Mine sets flat on fender well in my Bronco.
Old Nov 11, 2011 | 02:58 PM
Cody_302's Avatar
Cody_302
guess ill seal it up and hope for the best. thanks
Old Nov 11, 2011 | 03:05 PM
HIO Silver's Avatar
HIO Silver
ME!!! I cleaned it up last summer, sealed it with RTV, and it barfed again. Removal? Strap on your patience, scrape off as much as possible, and then use mineral spirits and lots of rags.
I'm gonna bend up a tray so it will act as a reservoir to catch the goo.... also thinking of just replacing it and keeping the barfy one as an emergency spare.
Old Nov 11, 2011 | 03:12 PM
Cody_302's Avatar
Cody_302
anything that would be better to seal with besides rtv?
Old Nov 11, 2011 | 03:17 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Will give you some advice. If you have a wrecking yard available, scarf up a couple old Motorcraft modules. The cheap chinese replacements usually don't last long and the new good boxes are expensive. I need to make a trip myself since I just used my last one on my last project.
Old Nov 11, 2011 | 03:26 PM
HIO Silver's Avatar
HIO Silver
Mine is a Motorcraft and it still barfed. And yes, I plan to get another Motorcraft but will take a preventative measure... an ICM "diaper".
Old Nov 11, 2011 | 06:18 PM
Cody_302's Avatar
Cody_302
I will most likely make some kind of under tray also because that stuff is not an easy clean up.
Old Nov 11, 2011 | 07:00 PM
fmc400's Avatar
fmc400
MSEE
If the epoxy has melted, the module needs to be replaced. The epoxy can be scraped off with a gasket scraper.
If the leaking/overheating happens with multiple modules, then the ignition system was modified incorrectly in some way; either the ballast resistor was bypassed or an aftermarket "performance" coil with too small of a primary winding resistance was installed.
Old Nov 11, 2011 | 07:17 PM
OldStyle's Avatar
OldStyle
Rusty Roller
I have owned many vehicles with both factory and "cheap" modules and never had one melt down... Just days ago I was checking my turn signals and forgot to turn my ign off. Two days later my deep cycle battery was dead. On the charger for a couple of hours and she fired right up!
Stone1981F-150
Apr 27, 2018 07:06 AM
GWL
Oct 18, 2009 08:25 PM
Chumbucket
Sep 8, 2006 09:22 AM
mk84bronco
1978 - 1996 Big Bronco
Jan 16, 2004 01:56 PM
