1978 - 1996 Big Bronco
No ignition box
Old Jan 15, 2004 | 01:13 PM
mk84bronco's Avatar
mk84bronco
No ignition box
My 84 bronco has many "issues"one being thet there is no ignition box.It has a mallory coil and distributor but there is not an ignition box in sight.Should there be?If it has a factory one where the hell is it?Things that make you go hummmmm....
Old Jan 15, 2004 | 01:19 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Does the truck run?
It should be on the drivers side fender well, near the firewall.
Old Jan 15, 2004 | 01:27 PM
mk84bronco's Avatar
mk84bronco
Believe it or not it runs pretty good.Skips just a hair but thats due to timing.Like I said.....things that make you go hummm........
Old Jan 15, 2004 | 02:42 PM
Bronco86's Avatar
Bronco86
i couldn't find mine either
Old Jan 16, 2004 | 01:27 AM
DW2455's Avatar
DW2455
if it has a Mallory unilite dist. or dual point, then there wont be an ignition box. just a dist. and coil. DW
Old Jan 16, 2004 | 01:56 PM
mk84bronco's Avatar
mk84bronco
Thanks DW2455 I remembered that after i made this post,just had a brain fart i guess.
Bruce
Jun 7, 2016 03:28 PM
94Bronco2215
Jul 28, 2015 07:35 PM
jmoe
Jan 15, 2011 03:21 AM
cfrives3
Feb 24, 2008 04:46 PM
topher
Jun 25, 2000 12:58 AM
