hi guys, i have a friend who has a 99 f-150 5.4 v8. i'm trying to help him. he mentioned tat in the morning, when he starts the truck up, and if he decides to shift right away to drive off, it appears rough with a slight "thud" when he shifts. not loud but a slight jerking "thud".
now, when he lets it sit there for bout 3 to 4 mins, it shifts fine with no thud watsoever. truck has over 230,000 miles on it. not sure bout transmission fluid change. could it be battery or just changing the transmission fluid?
appreciate all y'alls help in advance.
Is he shifting into gear at high idle?
These engines rev high when first started cold.Mine is around 1400 rpm for at least 30 seconds.
What do you expect to happen when shifting into drive at 1400 rpm with cold transmission fluid?
The trans won't even go into 'overdrive, until the fluid heats up to about 95 degrees.
Here are the reasons it takes time for the idle to come down to normal.
..On a cold start the head temperature is looked at from the head sensor when the ignition switch is operated to the 'run' position before cranking the motor.
..This sets the IAC open full, the fuel injected amounts are increased, the ignition timing is advanced.
..At crank and fire, the idle is high depending on the temperature seen just before cranking.
..As the OX sensors heat up and the head temperture begins to rise, the idle is allowed to lower by computer step logic decision, as these values change.
In very low temperatures the high idle will remain higher for a longer period of time before beginning to lower until temperature of the motor begins to rise.
Bottom line: If you didnot have these functions in place you could not drive off with a cold engine without stalling. I just know you would love that!
Also dropping a transmission into gear at higher rpm shocks the drive line.
This is the way all modern engines react to low temperature.
I think some body needs to slow their life down just a bit and be more reasonable.
